Datasheet HMC363G8 (Analog Devices) - 3
DescriptionSMT GaAs HBT MMIC DIVIDE-BY-8, DC - 12 GHz
Pages / Page6 / 3 — HMC363G8. SMT GaAs HBT MMIC. DIVIDE-BY-8, DC - 12 GHz. Output Voltage …
File Format / SizePDF / 327 Kb
HMC363G8. SMT GaAs HBT MMIC. DIVIDE-BY-8, DC - 12 GHz. Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC363G8 SMT GaAs HBT MMIC DIVIDE-BY-8, DC - 12 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC363G8
v00.0203
6
Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C Absolute Maximum Ratings
600 T RF Input (Vcc = +5V) +13 dBm Vcc +5.5V 400 Channel Temperature (Tc) 135 °C 200 Continuous Pdiss (T= 85 °C) 609 mW (derate 12.2 mW/ °C above 85 °C) S - SM 0 Storage Temperature -65 to +150 °C R Operating Temperature -40 to +85 °C AMPLTIUDE (mV) -200 O Thermal Resistance T 82 °C/W -400 (junction to ground paddle) C E -600 22.7 23.1 23.5 23.9 24.3 24.7 ELECTROSTATIC SENSITIVE DEVICE T TIME (nS) OBSERVE HANDLING PRECAUTIONS E
Typical Supply Current vs. Vcc
Vcc (V) Icc (mA) & D S 4.75 85 R 5.0 90 E 5.25 100 Note: Divider will operate over full voltage range shown above ID IV
Outline Drawing
Y D NC E U Q E R F NOTES: 1. PACKAGE MATERIAL: ALUMINA LOADED BOROSILICATE GLASS. 2. LEAD, BASE, COVER MATERIAL: KOVAR™ (#7052 CORNING). 3. PLATING: ELECTROLYTIC GOLD 50 MICROINCHES MIN., OVER ELECTROLYTIC NICKEL 50 MICROINCHES MIN. 4. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 5. TOLERANCES: ±.005 [0.13] UNLESS OTHERWISE SPECIFIED. 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
6 - 16
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Pho - n 25 e: 7 0- 81 3 3 3 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
