Datasheet ADM1041A (Analog Devices) - 8
DescriptionSecondary-Side Controller with Current Share and Housekeeping
Pages / Page56 / 8 — ADM1041A. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
ADM1041A Parameter Min Typ Max Unit Test Conditions/Comments
link to page 46 link to page 46 link to page 46 link to page 46 link to page 46 link to page 46 link to page 45 link to page 40 link to page 21 link to page 46 link to page 46 link to page 40 link to page 46 link to page 40 link to page 46 link to page 45 link to page 21 link to page 45 link to page 37 link to page 13 link to page 13
DC Offset Trim Range (with Respect to Input) −8 mV Reg 17h[2:0] = 000. See Table 32 . −15 mV Reg 17h[2:0] = 001. See Table 32. −30 mV Reg 17h[2:0] = 010. See Table 32. 8 mV Reg 17h[2:0] = 100. See Table 32. 15 mV Reg 17h[2:0] = 101. See Table 32. 30 mV Reg 17h[2:0] = 110. See Table 32. DC Offset Trim Step Size 30 μV VCM = 2.0 V, VDIFF = 0 V (with respect to input) 50 μV 8 bits, 255 steps 120 μV Reg 15h[7:0]. See Table 30. CURRENT SENSE CALIBRATION Total Current Sense Error2 VCSCM = 2.0V, 0°C ≤ TA ≤ 85°C, (Gain and Offset) SHRS = SHRO = 2 V. Gain = 230x. ±3 % Chopper on ±6 % Chopper off Gain Range (ISENSE) Max input voltage range at CS+, CS− Gain Setting 1 (Reg 16h[2:0] = 000) 65 V/V 34 mV – 44.5 mV. Gain = 65×. Gain Setting 2 (Reg 16h[2:0] = 001) 85 V/V 26 mV – 34 mV. Gain = 85×. Gain Setting 3 (Reg 16h[2:0] = 010) 110 V/V 20 mV – 26 mV. Gain = 110×. Gain Setting 4 (Reg 16h[2:0] = 100) 135 V/V 16 mV – 20 mV. Gain = 135×. Gain Setting 5 (Reg 16h[2:0] = 101) 175 V/V 12 mV – 16 mV. Gain = 175×. Gain Setting 6 (Reg 16h[2:0] = 110) 230 V/V 9.5 mV – 12 mV. Gain = 230× Full Scale (No Offset) 2.0 V VZO = 0 Attenuation Range 65 to 99 % Reg 06h[7:1]. See Table 15. Current Share Trim Step (at SHRO) 0.4 % SHRS = SHRO = 1 V 8 mV 7 bits, 127 steps ISHARE slope Gain Accuracy2, 4, 40 mV at CS+, CS− −5 +5 % 0 V ≤ VCSCM ≤ 0.3 V. Gain = 65×. VCSCM = input common mode. Gain Accuracy2, 4, 20 mV at CS+, CS− −5 ±1 +5 % VCSCM = 2.0 V, 0°C ≤ TA ≤ 85°C. Gain = 135× Gain Accuracy2, 4, 40 mV at CS+, CS– −2.5 ±0.5 +2.5 % VCSCM = 2.0 V, 0°C ≤ TA ≤ 85°C. Gain = 65× SHARE BUS OFFSET See Figure 13. Current Share Offset Range 1.25 V Reg 17h[7] = 1. See Table 32. Reg 17h[5] = 1. See Table 32. Zero Current Offset Trim Step 0 ≤ VTRIM ≤ 1.25 V 0.4 % 8 bits, 255 steps, VCT = 1.0 V 5.5 mV Reg 05h[7:0]. See Table 14. CURRENT TRANSFORMER SENSE INPUT, ICT Reg 17h[7] = 1. See Table 32. Reg 06h = FEh. See Table 15. Gain Setting 0 4.5 V/V Reg 17h[5] = 0, VSHARE = 2 V. See Table 31 Gain Setting 1 2.57 V/V Reg 17h[5] = 1. See Table 32. Reg 15h = 05h, approx 1 μA. See Table 30. VSHARE = 2 V. CT Input Sensitivity 0.45 0.5 0.68 V Gain setting = 4.5 CT Input Sensitivity 0.79 1.0 1.20 V Gain setting = 2.57 Input Impedance2 20 50 kΩ Source Current 2.0 μA See Current-Transformer Input Section. Source Current Step Size 170 nA 15 steps Reg 15h[3:0]. See Table 30. Reverse Current for Extended SMBus 3.5 5 7 mA See Figure 38 and the Absolute Addressing (Source Current) 5 Maximum Ratings section. Rev. 0 | Page 8 of 56 Document Outline FEATURES SECONDARY-SIDE FEATURES INTERFACE AND INTERNAL FEATURES APPLICATIONS GENERAL DESCRIPTION SAMPLE APPLICATION CIRCUIT DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY THEORY OF OPERATION POWER MANAGEMENT GAIN TRIMMING AND CONFIGURATION DIFFERENTIAL REMOTE SENSE AMPLIFIER SET LOAD VOLTAGE LOAD OVERVOLTAGE (OV) LOCAL VOLTAGE SENSE LOCAL OVERVOLTAGE PROTECTION (OVP) LOCAL UNDERVOLTAGE PROTECTION (UVP) FALSE UV CLAMP VOLTAGE ERROR AMPLIFIER MAIN VOLTAGE REFERENCE CURRENT-SENSE AMPLIFIER CURRENT SENSING CURRENT-TRANSFORMER INPUT CURRENT-SENSE CALIBRATION CURRENT-LIMIT ERROR AMPLIFIER OVERCURRENT PROTECTION CURRENT SHARE CURRENT-SHARE OFFSET ISHARE DRIVE AMPLIFIER DIFFERENTIAL SENSE AMPLIFIER ISHARE ERROR AMPLIFIER ISHARE CLAMP SHARE_OK DETECTOR PULSE/ACSENSE2 PULSE ACSENSE OrFET GATE DRIVE OSCILLATOR AND TIMING GENERATORS LOGIC I/O AND MONITOR PINS CBD/ALERT MON1 MON2 PEN PSON MON3 DC_OK (POWER-OK, POWER Good, Etc.) MON4 AC_OK MON5 SMBus SERIAL PORT MICROPROCESSOR SUPPORT Interfacing Configuring for a Microprocessor BROADCASTING SMBus SERIAL INTERFACE GENERAL SMBus TIMING SMBus PROTOCOLS FOR RAM AND EEPROM SMBus Erase EEPROM Page Operations SMBus Write Operations Send Byte Write Byte/Word Block Write SMBus READ OPERATIONS Receive Byte Block Read Notes on SMBus Read Operations SMBus ALERT RESPONSE ADDRESS (ARA) SUPPORT FOR SMBus 1.1 LAYOUT CONSIDERATIONS POWER-UP AUTO-CONFIGURATION EXTENDED SMBus ADDRESSING SDA/PSONLINK SCL/AC_OKLink BACKDOOR ACCESS REGISTER LISTING DETAILED REGISTER DESCRIPTIONS MANUFACTURING DATA MICROPROCESSOR SUPPORT TEST NAME TABLE OUTLINE DIMENSIONS ORDERING GUIDE
