Datasheet ATmega165, ATmega165V - Preliminary Summary (Atmel)
ManufacturerAtmel
Pages / Page19 / 1 — Features. High Performance, Low Power AVR. 8-Bit Microcontroller. …
File Format / SizePDF / 340 Kb
Features. High Performance, Low Power AVR. 8-Bit Microcontroller. Advanced RISC Architecture
Datasheet ATmega165, ATmega165V - Preliminary Summary Atmel
Features
Advanced RISC Architecture – 130 Powerful Instructions – Most Single Clock Cycle Execution – 32 x 8 General Purpose Working Registers – Fully Static Operation – Up to 16 MIPS Throughput at 16 MHz – On-Chip 2-cycle Multiplier
Non-volatile Program and Data Memories – 16K bytes of In-System Self-Programmable Flash Endurance: 10,000 Write/Erase Cycles 8-bit – Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program Microcontroller True Read-While-Write Operation – 512 bytes EEPROM with 16K Bytes Endurance: 100,000 Write/Erase Cycles – 1K byte Internal SRAM In-System – Programming Lock for Software Security
JTAG (IEEE std. 1149.1 compliant) Interface – Boundary-scan Capabilities According to the JTAG Standard Programmable – Extensive On-chip Debug Support – Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Flash
Peripheral Features – Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode – One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ATmega165V – Real Time Counter with Separate Oscillator – Four PWM Channels ATmega165 – 8-channel, 10-bit ADC – Programmable Serial USART – Master/Slave SPI Serial Interface – Universal Serial Interface with Start Condition Detector Preliminary – Programmable Watchdog Timer with Separate On-chip Oscillator – On-chip Analog Comparator – Interrupt and Wake-up on Pin Change Summary
Special Microcontroller Features – Power-on Reset and Programmable Brown-out Detection – Internal Calibrated Oscillator – External and Internal Interrupt Sources – Five Sleep Modes: Idle, ADC Noise Reduction, Power-save, Po
wer-down, and Standby
I/O and Packages – 53 Programmable I/O Lines2573GS – 64-lead TQFP and 64-pad QFN/MLF
Speed Grade: – ATmega165V: 0 - 4 MHz @ 1.8 - 5.5V, 0 - 8 MHz @ 2.7 - 5.5V – ATmega165: 0 - 8 MHz @ 2.7 - 5.5V, 0 - 16 MHz @ 4.5 - 5.5V
Temperature range: – -40°C to 85°C Industrial
Ultra-Low Power Consumption
Notice:
– Active Mode:
Not recommended in new
1 MHz, 1.8V: 350µA
designs.
32 kHz, 1.8V: 20µA (including Oscillator) – Power-down Mode: 0.1µA at 1.8V
2573GS–AVR–07/09 Note: This is a summary document. A complete document is available on our Web site at www.atmel.com. Document Outline Features Pin Configurations Disclaimer Overview Block Diagram Pin Descriptions VCC GND Port A (PA7..PA0) Port B (PB7..PB0) Port C (PC7..PC0) Port D (PD7..PD0) Port E (PE7..PE0) Port F (PF7..PF0) Port G (PG4..PG0) RESET XTAL1 XTAL2 AVCC AREF Register Summary Instruction Set Summary Ordering Information Packaging Information 64A 64M1 Errata ATmega165 Rev A Datasheet Revision History Changes from Rev. 2573F-08/06 to Rev. 2573G-07/09 Changes from Rev. 2573E-07/06 to Rev. 2573F-08/06 Changes from Rev. 2573D-03/06 to Rev. 2573E-07/06 Changes from Rev. 2573C-03/06 to Rev. 2573D-03/06 Changes from Rev. 2573B-03/05 to Rev. 2573C-02/06 Changes from Rev. 2573A-06/04 to Rev. 2573B-03/05
