Datasheet AT90S8535, AT90LS8535 (Atmel)
ManufacturerAtmel
Description8-bit AVR Microcontroller with 8K Bytes In-System Programmable Flash
Pages / Page127 / 1 — Features. AVR® – High-performance and Low-power RISC Architecture
File Format / SizePDF / 2.5 Mb
Datasheet AT90S8535, AT90LS8535 Atmel
Features
AVR® – High-performance and Low-power RISC Architecture – 118 Powerful Instructions – Most Single Clock Cycle Execution – 32 x 8 General-purpose Working Registers – Up to 8 MIPS Throughput at 8 MHz
Data and Nonvolatile Program Memories – 8K Bytes of In-System Programmable Flash SPI Serial Interface for In-System Programming Endurance: 1,000 Write/Erase Cycles – 512 Bytes EEPROM Endurance: 100,000 Write/Erase Cycles 8-bit – 512 Bytes Internal SRAM – Programming Lock for Software Security Microcontroller
Peripheral Features – 8-channel, 10-bit ADC with 8K Bytes – Programmable UART – Master/Slave SPI Serial Interface – Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode In-System – One 16-bit Timer/Counter with Separate Prescaler, Compare and Capture Modes and Dual 8-, 9-, or 10-bit PWM Programmable – Programmable Watchdog Timer with On-chip Oscillator – On-chip Analog Comparator Flash
Special Microcontroller Features – Power-on Reset Circuit – Real-time Clock (RTC) with Separate Oscillator and Counter Mode – External and Internal Interrupt Sources AT90S8535 – Three Sleep Modes: Idle, Power Save and Power-down
Power Consumption at 4 MHz, 3V, 20
C AT90LS8535 – Active: 6.4 mA – Idle Mode: 1.9 mA – Power-down Mode: <1 µA
I/O and Packages – 32 Programmable I/O Lines – 40-lead PDIP, 44-lead PLCC, 44-lead TQFP, and 44-pad MLF
Operating Voltages – V : 4.0 - 6.0V AT90S8535 CC – V : 2.7 - 6.0V AT90LS8535 CC
Speed Grades: – 0 - 8 MHz for the AT90S8535 – 0 - 4 MHz for the AT90LS8535
Rev. 1041H–11/01
1
Document Outline Features Pin Configurations Description Block Diagram Pin Descriptions VCC GND Port A (PA7..PA0) Port B (PB7..PB0) Port C (PC7..PC0) Port D (PD7..PD0) RESET XTAL1 XTAL2 AVCC AREF AGND Clock Options Crystal Oscillator External Clock Timer Oscillator Architectural Overview General-purpose Register File X-register, Y-register and Z- register ALU – Arithmetic Logic Unit In-System Programmable Flash Program Memory SRAM Data Memory Program and Data Addressing Modes Register Direct, Single Register Rd Register Direct, Two Registers Rd And Rr I/O Direct Data Direct Data Indirect with Displacement Data Indirect Data Indirect with Pre- decrement Data Indirect with Post- increment Constant Addressing Using the LPM Instruction Indirect Program Addressing, IJMP and ICALL Relative Program Addressing, RJMP and RCALL EEPROM Data Memory Memory Access Times and Instruction Execution Timing I/O Memory Status Register – SREG Stack Pointer – SP Reset and Interrupt Handling Reset Sources Power-on Reset External Reset Watchdog Reset MCU Status Register – MCUSR Interrupt Handling General Interrupt Mask Register – GIMSK General Interrupt Flag Register – GIFR Timer/Counter Interrupt Mask Register – TIMSK Timer/Counter Interrupt Flag Register – TIFR External Interrupts Interrupt Response Time MCU Control Register – MCUCR Sleep Modes Idle Mode Power-down Mode Power Save Mode Timer/Counters Timer/Counter Prescalers 8-bit Timer/Counter0 Timer/Counter0 Control Register – TCCR0 Timer Counter 0 – TCNT0 16-bit Timer/Counter1 Timer/Counter1 Control Register A – TCCR1A Timer/Counter1 Control Register B – TCCR1B Timer/Counter1 – TCNT1H AND TCNT1L Timer/Counter1 Output Compare Register – OCR1AH AND OCR1AL Timer/Counter1 Output Compare Register – OCR1BH AND OCR1BL Timer/Counter1 Input Capture Register – ICR1H AND ICR1L Timer/Counter1 In PWM Mode 8-bit Timer/Counter2 Timer/Counter2 Control Register – TCCR2 Timer/Counter2 – TCNT2 Timer/Counter2 Output Compare Register – OCR2 Timer/Counter2 in PWM Mode Asynchronous Status Register – ASSR Asynchronous Operation of Timer/Counter2 Watchdog Timer Watchdog Timer Control Register – WDTCR EEPROM Read/Write Access EEPROM Address Register – EEARH and EEARL EEPROM Data Register – EEDR EEPROM Control Register – EECR Prevent EEPROM Corruption Serial Peripheral Interface – SPI SS Pin Functionality Data Modes SPI Control Register – SPCR SPI Status Register – SPSR SPI Data Register – SPDR UART Data Transmission Data Reception UART Control UART I/O Data Register – UDR UART Status Register – USR UART Control Register – UCR Baud Rate Generator UART Baud Rate Register – UBRR Analog Comparator Analog Comparator Control and Status Register – ACSR Analog-to-Digital Converter Feature list Operation Prescaling ADC Noise Canceler Function ADC Multiplexer Select Register – ADMUX ADC Control and Status Register – ADCSR ADC Data Register – ADCL AND ADCH Scanning Multiple Channels ADC Noise Canceling Techniques ADC Characteristics I/O Ports Port A Port A Data Register – PORTA Port A Data Direction Register – DDRA Port A Input Pins Address – PINA Port A as General Digital I/O Port A Schematics Port B Port B Data Register – PORTB Port B Data Direction Register – DDRB Port B Input Pins Address – PINB Port B As General Digital I/O Alternate Functions of Port B Port B Schematics Port C Port C Data Register – PORTC Port C Data Direction Register – DDRC Port C Input Pins Address – PINC Port C As General Digital I/O Alternate Functions of Port C Port C Schematics Port D Port D Data Register – PORTD Port D Data Direction Register – DDRD Port D Input Pins Address – PIND Port D As General Digital I/O Alternate Functions of Port D Port D Schematics Memory Programming Program and Data Memory Lock Bits Fuse Bits Signature Bytes Programming the Flash and EEPROM Parallel Programming Signal Names Enter Programming Mode Chip Erase Programming the Flash Reading the Flash Programming the EEPROM Reading the EEPROM Programming the Fuse Bits Programming the Lock Bits Reading the Fuse and Lock Bits Reading the Signature Bytes Parallel Programming Characteristics Serial Downloading Serial Programming Algorithm Data Polling EEPROM Data Polling Flash Serial Programming Characteristics Electrical Characteristics Absolute Maximum Ratings* DC Characteristics External Clock Drive Waveforms Typical Characteristics Register Summary Instruction Set Summary Ordering Information Packaging Information 44A 44J 40P6 44M1
