Datasheet ADuM5200, ADuM5201, ADuM5202 (Analog Devices) - 8
DescriptionDual-Channel, 2.5 kV Isolators with Integrated DC-to-DC Converter
Pages / Page28 / 8 — ADuM5200/ADuM5201/ADuM5202. Data Sheet. Table 13. Input and Output …
File Format / SizePDF / 491 Kb
ADuM5200/ADuM5201/ADuM5202. Data Sheet. Table 13. Input and Output Characteristics Parameter Symbol. Min. Typ. Max. Unit. Test
ADuM5200/ADuM5201/ADuM5202 Data Sheet Table 13 Input and Output Characteristics Parameter Symbol Min Typ Max Unit Test
link to page 8
ADuM5200/ADuM5201/ADuM5202 Data Sheet Table 13. Input and Output Characteristics Parameter Symbol Min Typ Max Unit Test Conditions
DC SPECIFICATIONS Logic High Input Threshold VIH 0.7 VISO or 0.7 VDD1 V Logic Low Input Threshold VIL 0.3 VISO or 0.3 VDD1 V Logic High Output Voltages VOH VDD1 − 0.2, VISO − 0.2 VDD1 or VISO V IOx = −20 μA, VIx = VIxH VDD1 − 0.5 or VDD1 − 0.2 or V IOx = −4 mA, VIx = VIxH VISO − 0.5 VISO − 0.2 Logic Low Output Voltages VOL 0.0 0.1 V IOx = 20 μA, VIx = VIxL 0.0 0.4 V IOx = 4 mA, VIx = VIxL Undervoltage Lockout VDD1, VDDL, VISO supplies Positive Going Threshold VUV+ 2.7 V Negative Going Threshold VUV− 2.4 V Hysteresis VUVH 0.3 V Input Currents per Channel II −20 +0.01 +20 μA 0 V ≤ VIx ≤ VDDx AC SPECIFICATIONS Output Rise/Fall Time tR/tF 2.5 ns 10% to 90% Common-Mode Transient |CM| 25 35 kV/μs VIx = VDD1 or VISO, VCM = 1000 V, Immunity1 transient magnitude = 800 V Refresh Rate fr 1.0 Mbps 1 |CM| is the maximum common-mode voltage slew rate that can be sustained while maintaining VO > 0.7 × VDD1 or 0.7 × VISO for a high output or VO < 0.3 × VDD1 or 0.3 × VISO for a low output. The common-mode voltage slew rates apply to both rising and falling common-mode voltage edges. Rev. B | Page 8 of 28 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Information Insulation and Safety-Related Specifications IEC 60747-5-2 (VDE 0884, Part 2):2003-01 Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Applications Information PCB Layout Start-Up Behavior EMI Considerations Propagation Delay Parameters DC Correctness and Magnetic Field Immunity Power Consumption Current Limit and Thermal Overload Protection Power Considerations Thermal Analysis Increasing Available Power Insulation Lifetime Outline Dimensions Ordering Guide
