Datasheet ADuM5200, ADuM5201, ADuM5202 (Analog Devices) - 9
DescriptionDual-Channel, 2.5 kV Isolators with Integrated DC-to-DC Converter
Pages / Page28 / 9 — Data Sheet. ADuM5200/ADuM5201/ADuM5202. PACKAGE CHARACTERISTICS. Table …
RevisionB
File Format / SizePDF / 491 Kb
Data Sheet. ADuM5200/ADuM5201/ADuM5202. PACKAGE CHARACTERISTICS. Table 14. Thermal and Isolation Characteristics Parameter
Data Sheet ADuM5200/ADuM5201/ADuM5202 PACKAGE CHARACTERISTICS Table 14 Thermal and Isolation Characteristics Parameter
link to page 9 link to page 11 link to page 24 link to page 9 link to page 9 link to page 9 link to page 22 link to page 9 link to page 9 link to page 9 link to page 9
Data Sheet ADuM5200/ADuM5201/ADuM5202 PACKAGE CHARACTERISTICS Table 14. Thermal and Isolation Characteristics Parameter Symbol Min Typ Max Unit Test Conditions
RESISTANCE AND CAPACITANCE Resistance (Input-to-Output)1 RI-O 102 Ω Capacitance (Input-to-Output)1 CI-O 2.2 pF f = 1 MHz Input Capacitance2 CI 4.0 pF IC Junction to Ambient Thermal Resistance θJA 45 °C/W Thermocouple located at the center of the package underside; test conducted on a 4-layer board with thin traces 3 THERMAL SHUTDOWN Threshold TSSD 150 °C TJ rising Hysteresis TSSD-HYS 20 °C 1 This device is considered a 2-terminal device; Pin 1 through Pin 8 are shorted together, and Pin 9 through Pin 16 are shorted together. 2 Input capacitance is from any input data pin to ground. 3 Refer to the Power Considerations section for thermal model definitions.
REGULATORY INFORMATION
The ADuM5200/ADuM5201/ADuM5202 are approved by the organizations listed in Table 15. Refer to Table 20 and the Insulation Lifetime section for more information about the recommended maximum working voltages for specific cross-insulation waveforms and insulation levels.
Table 15. UL1 CSA VDE (Pending)2
Recognized under UL 1577 component Approved under CSA Component Certified according to IEC 60747-5-2 recognition program1 Acceptance Notice #5A (VDE 0884, Part 2):2003-012 Single protection, 2500 V rms Testing was conducted per CSA 60950-1-07 Basic insulation, 560 VPEAK isolation voltage and IEC 60950-1 2nd Ed. at 2.5 kV rated voltage Basic insulation at 600 V rms (848 VPEAK) working voltage Reinforced insulation at 250 V rms (353 VPEAK) working voltage File E214100 File 205078 File 2471900-4880-0001 1 In accordance with UL 1577, each ADuM5200/ADuM5201/ADuM5202 is proof tested by applying an insulation test voltage ≥ 3000 V rms for 1 second (current leakage detection limit = 10 μA). 2 In accordance with IEC 60747-5-2 (VDE 0884 Part 2):2003-01, each ADuM520x is proof tested by applying an insulation test voltage ≥ 1590 VPEAK for 1 second (partial discharge detection limit = 5 pC). The asterisk (*) marking branded on the component designates IEC 60747-5-2 (VDE 0884, Part 2):2003-01 approval.
INSULATION AND SAFETY-RELATED SPECIFICATIONS Table 16. Critical Safety-Related Dimensions and Material Properties Parameter Symbol Value Unit Test Conditions/Comments
Rated Dielectric Insulation Voltage 2500 V rms 1-minute duration Minimum External Air Gap L(I01) 8.0 mm Distance measured from input terminals to output terminals; shortest distance through air along the PCB mounting plane, as an aid to PC board layout Minimum External Tracking (Creepage) L(I02) 7.6 mm Measured from input terminals to output terminals, shortest distance path along body Minimum Internal Distance (Internal Clearance) 0.017 min mm Distance through insulation Tracking Resistance (Comparative Tracking Index) CTI >175 V DIN IEC 112/VDE 0303, Part 1 Isolation Group IIIa Material group (DIN VDE 0110, 1/89, Table 1) Rev. B | Page 9 of 28 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Information Insulation and Safety-Related Specifications IEC 60747-5-2 (VDE 0884, Part 2):2003-01 Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Applications Information PCB Layout Start-Up Behavior EMI Considerations Propagation Delay Parameters DC Correctness and Magnetic Field Immunity Power Consumption Current Limit and Thermal Overload Protection Power Considerations Thermal Analysis Increasing Available Power Insulation Lifetime Outline Dimensions Ordering Guide
