link to page 9 link to page 22 link to page 9 link to page 11 link to page 24 link to page 24 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 Automotive ProductsADuM5200W/ADuM5201W/ADuM5202WPACKAGE CHARACTERISTICSTable 14. Thermal and Isolation Characteristics ParameterSymbol Min Typ Max UnitTest Conditions/Comments RESISTANCE AND CAPACITANCE Resistance (Input-to-Output)1 R 102 Ω I-O Capacitance (Input-to-Output)1 C 2.2 pF f = 1 MHz I-O Input Capacitance2 C 4.0 pF I IC Junction to Ambient Thermal Resistance θ 45 °C/W Thermocouple located at the center of the package JA underside; test conducted on a 4-layer board with thin traces 3 THERMAL SHUTDOWN Threshold TS 150 °C T rising SD J Hysteresis TS 20 °C SD-HYS 1 This device is considered a 2-terminal device; Pin 1 through Pin 8 are shorted together, and Pin 9 through Pin 16 are shorted together. 2 Input capacitance is from any input data pin to ground. 3 Refer to the Power Considerations section for thermal model definitions. REGULATORY INFORMATION The ADuM5200W/ADuM5201W/ADuM5202W are approved by the organizations listed in Table 15. Refer to Table 20 and the Insulation Lifetime section for more information about the recommended maximum working voltages for specific cross-insulation waveforms and insulation levels. Table 15. UL1CSAVDE2 Recognized under 1577 component Approved under CSA Component Certified according to IEC 60747-5-2 recognition program1. Acceptance Notice #5A. (VDE 0884, Part 2):2003-012. Single protection, 2500 V rms Testing was conducted per CSA 60950-1-07 Basic insulation, 560 V . PEAK isolation voltage. and IEC 60950-1 2nd Ed. at 2.5 kV rated voltage. Basic insulation at 600 V rms (848 V ) PEAK working voltage. Reinforced insulation at 250 V rms (353 V ) PEAK working voltage. File E214100. File 205078. File 2471900-4880-0001. 1 In accordance with UL 1577, each ADuM5200W/ADuM5201W/ADuM5202W is proof tested by applying an insulation test voltage ≥ 3000 V rms for 1 second (current leakage detection limit = 10 µA). 2 In accordance with to IEC 60747-5-2 (VDE 0884 Part 2):2003-01, each ADuM520x is proof tested by applying an insulation test voltage ≥1590 VPEAK for 1 second (partial discharge detection limit = 5 pC). The * marking branded on the component designates IEC 60747-5-2 (VDE 0884, Part 2):2003-01 approval. INSULATION AND SAFETY-RELATED SPECIFICATIONSTable 16. Critical Safety-Related Dimensions and Material Properties ParameterSymbol ValueUnit Test Conditions/Comments Rated Dielectric Insulation Voltage 2500 V rms 1-minute duration Minimum External Air Gap L(I01) 8.0 mm Distance measured from input terminals to output terminals; shortest distance through air along the PCB mounting plane, as an aid to PC board layout Minimum External Tracking (Creepage) L(I02) 7.6 mm Measured from input terminals to output terminals, shortest distance path along body Minimum Internal Distance (Internal Clearance) 0.017 min mm Distance through insulation Tracking Resistance (Comparative Tracking Index) CTI >175 V DIN IEC 112/VDE 0303, Part 1 Isolation Group IIIa Material group (DIN VDE 0110, 1/89, Table 1) Rev. 0 | Page 9 of 28 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Information Insulation and Safety-Related Specifications IEC 60747-5-2 (VDE 0884, Part 2):2003-01 Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Applications Information PCB Layout Start-Up Behavior EMI Considerations Propagation Delay Parameters DC Correctness and Magnetic Field Immunity Power Consumption Current Limit and Thermal Overload Protection Power Considerations Thermal Analysis Increasing Available Power Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
