Datasheet ADR3512 (Analog Devices)
DescriptionMicropower, High Accuracy Voltage Reference
Pages / Page16 / 1 — Micropower, High Accuracy. Voltage Reference. Data Sheet. ADR3512. …
RevisionE
File Format / SizePDF / 819 Kb
Micropower, High Accuracy. Voltage Reference. Data Sheet. ADR3512. FEATURES. PIN CONFIGURATION. Maximum temperature coefficient
Datasheet ADR3512 Analog Devices, Revision: E
Micropower, High Accuracy Voltage Reference Data Sheet ADR3512 FEATURES PIN CONFIGURATION Maximum temperature coefficient ENABLE 1 8 VIN 4 ppm/°C (C grade, −40°C to +85°C) GND SENSE ADR3512 2 7 VOUT SENSE TOP VIEW Low long-term drift (LTD): 30 ppm (initial 1 khr typical) GND FORCE 3 6 VOUT FORCE (Not to Scale) Initial output voltage error: ±0.1% (maximum) DNC 4 5 DNC Operating temperature range: −40°C to +125°C NOTES
001 13-
Output current: +10 mA source/−3 mA sink 1. DNC = DO NOT CONNECT. DO NOT CONNECT TO THIS PIN.
111
Low quiescent current: 100 µA (maximum)
Figure 1. 8-Lead MSOP (RM-8 Suffix)
Low dropout voltage: 1.15 V at 2 mA Output voltage noise (0.1 Hz to 10 Hz): 8 µV p-p (typical) Qualified for automotive applications APPLICATIONS Automotive battery monitors Portable instrumentation Process transmitters Remote sensors Medical instrumentation GENERAL DESCRIPTION
The ADR3512 is a low cost, low power, high precision CMOS The low output voltage hysteresis and low long-term output voltage voltage reference, featuring a maximum temperature coefficient drift improve lifetime system accuracy. (TC) of 4 ppm/°C (C grade, −40°C to +85°C), low operating This CMOS reference is specified over the automotive temperature current, and low output noise in an 8-lead MSOP package. For range of −40°C to +125°C. high accuracy, the output voltage and temperature coefficient are trimmed digitally during final assembly using the Analog
Table 1. Selection Guide
Devices, Inc., patented DigiTrim® technology.1
Output Input Voltage Model Voltage (V) Range (V)
ADR3512WCRMZ-R7 1.200 2.3 to 5.5 1 At least U.S. Patent No. 6,696,894 covers this technology.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION LONG-TERM OUTPUT VOLTAGE DRIFT POWER DISSIPATION APPLICATIONS INFORMATION BASIC VOLTAGE REFERENCE CONNECTION INPUT AND OUTPUT CAPACITORS 4-WIRE KELVIN CONNECTIONS VIN SLEW RATE CONSIDERATIONS SHUTDOWN/ENABLE FEATURE SAMPLE APPLICATIONS Negative Reference Bipolar Output Reference Boosted Output Current Reference OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
