Datasheet ADR3512 (Analog Devices) - 5
DescriptionMicropower, High Accuracy Voltage Reference
Pages / Page16 / 5 — Data Sheet. ADR3512. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. ENABLE. …
RevisionE
File Format / SizePDF / 819 Kb
Data Sheet. ADR3512. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. ENABLE. VIN. GND SENSE. VOUT SENSE. TOP VIEW. GND FORCE. VOUT FORCE
Data Sheet ADR3512 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS ENABLE VIN GND SENSE VOUT SENSE TOP VIEW GND FORCE VOUT FORCE
Data Sheet ADR3512 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS ENABLE 1 8 VIN GND SENSE ADR3512 2 7 VOUT SENSE TOP VIEW GND FORCE 3 6 VOUT FORCE (Not to Scale) DNC 4 5 DNC NOTES
002 13-
1. DNC = DO NOT CONNECT. DO NOT CONNECT TO THIS PIN.
111 Figure 2. Pin Configuration
Table 5. Pin Function Descriptions Pin No. Mnemonic Description
1 ENABLE Enable Connection. This pin enables or disables the device. 2 GND SENSE Ground Voltage Sense Connection. Connect this pin directly to the point of the lowest potential in the application. 3 GND FORCE Ground Force Connection. 4 DNC Do Not Connect. Do not connect to this pin. 5 DNC Do Not Connect. Do not connect to this pin. 6 VOUT FORCE Reference Voltage Output. 7 VOUT SENSE Reference Voltage Output Sensing Connection. Connect this pin directly to the voltage input of the load devices. 8 VIN Input Voltage Connection. Rev. E | Page 5 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION LONG-TERM OUTPUT VOLTAGE DRIFT POWER DISSIPATION APPLICATIONS INFORMATION BASIC VOLTAGE REFERENCE CONNECTION INPUT AND OUTPUT CAPACITORS 4-WIRE KELVIN CONNECTIONS VIN SLEW RATE CONSIDERATIONS SHUTDOWN/ENABLE FEATURE SAMPLE APPLICATIONS Negative Reference Bipolar Output Reference Boosted Output Current Reference OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
