Datasheet LT1236LS8 (Analog Devices) - 6
DescriptionPrecision, Low Noise, Low Profile Hermetic Voltage Reference
Pages / Page16 / 6 — pin FuncTions. NC (Pins 1, 3, 7, 8):. TRIM (Pin 5):. IN (Pin 2):. VOUT …
File Format / SizePDF / 233 Kb
pin FuncTions. NC (Pins 1, 3, 7, 8):. TRIM (Pin 5):. IN (Pin 2):. VOUT (Pin 6):. GND (Pin 4):. block DiagraM
pin FuncTions NC (Pins 1, 3, 7, 8): TRIM (Pin 5): IN (Pin 2): VOUT (Pin 6): GND (Pin 4): block DiagraM
LT1236LS8
Connected internally, do not connect.
TRIM (Pin 5):
Allows adjustment of output voltage. See
V
Applications Information section for details.
IN (Pin 2):
Power Supply. Bypass with 0.1µF (or larger) capacitor to ground.
VOUT (Pin 6):
Output Voltage. See Applications Information
GND (Pin 4):
Device Ground. See Applications Information section for details regarding DC and capacitive loading section for recommended connection methods. and stability.
block DiagraM
INPUT Q2 R1 OUTPUT R2 D6 – + D5 6.3V A1 R3 R4 D3 TRIM D4 Q1 GND 1236sl8 ES 1236ls8f 6 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
