Datasheet ADR3525, ADR3530, ADR3533, ADR3540, ADR3550 (Analog Devices) - 10
Description | Micropower, Precision, Auto Qualified 5.0V Voltage Reference |
Pages / Page | 20 / 10 — ADR3525/ADR3530/ADR3533/ADR3540/ADR3550. Data Sheet. TYPICAL PERFORMANCE … |
Revision | B |
File Format / Size | PDF / 789 Kb |
ADR3525/ADR3530/ADR3533/ADR3540/ADR3550. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 2.5010. 5.0025. VIN = 5.5V. 2.5008. 5.0020
ADR3525/ADR3530/ADR3533/ADR3540/ADR3550 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
TA = 25°C, unless otherwise noted.
2.5010 5.0025 VIN = 5.5V VIN = 5.5V 2.5008 5.0020 2.5006 5.0015 ) ) V 2.5004 V 5.0010 ( ( E G 2.5002 GE 5.0005 LTA LTA O 2.5000 O 5.0000 V V T T U 2.4998 U P 4.9995 T TP U 2.4996 O 4.9990 OU 2.4994 4.9985 2.4992 4.9980 2.4990
3
4.9975 –40 –25 –10 5 20 35 50 65 80 95 110 125
-00
006 94
TEMPERATURE (ºC)
594- 095
TEMPERATURE (ºC)
09 Figure 3. ADR3525 Output Voltage vs. Temperature Figure 6. ADR3550 Output Voltage vs. Temperature
40 45 35 40 35 30 S S 30 ICE 25 ICE V V E D 25 DE F 20 F R O 20 E BER O 15 B M U 15 N NUM 10 10 5 5 0 0
04 7
0 1 2 3 4 5 6 7 8 9 10 11
0
4- -00
TEMPERATURE COEFFICIENT (ppm/°C)
959 594 0
09 Figure 4. ADR3525 Temperature Coefficient Distribution Figure 7. ADR3550 Temperature Coefficient Distribution
24 35 ADR3525 ADR3525 22 IL = 0mA TO 10mA IL = 0mA TO –3mA ADR3530 SOURCING ADR3530 SINKING 20 ADR3533 ADR3533 30 ADR3540 ) ADR3540 18 ) /V ADR3550 /V ADR3550 16 ppm pm 25 ( (p N 14 O ON TI A 12 TI A 20 UL 10 UL G G E 8 15 AD RE AD R O 6 L O L 4 10 2 0
05
04-
-008
TEMPERATURE (°C)
959 594 0
TEMPERATURE (°C)
09 Figure 5. Load Regulation vs. Temperature (Sourcing) Figure 8. Load Regulation vs. Temperature (Sinking) Rev. A | Page 10 of 20 Document Outline Features Applications Pin Configuration General Description Revision History Specifications ADR3525 Electrical Characteristics ADR3530 Electrical Characteristics ADR3533 Electrical Characteristics ADR3540 Electrical Characteristics ADR3550 Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Long-Term Output Voltage Drift Power Dissipation Applications Information Basic Voltage Reference Connection Input and Output Capacitors 4-Wire Kelvin Connections VIN Slew Rate Considerations Shutdown/Enable Feature Sample Applications Negative Reference Bipolar Output Reference Boosted Output Current Reference Outline Dimensions Ordering Guide Automotive Products
