Datasheet LTC6652 (Analog Devices) - 6
Description | Precision Low Drift Low Noise Buffered Reference |
Pages / Page | 20 / 6 — t ypical perForMance characteristics Characteristic curves are similar … |
File Format / Size | PDF / 561 Kb |
t ypical perForMance characteristics Characteristic curves are similar for most
LTC6652
t ypical perForMance characteristics Characteristic curves are similar for most LTC6652s. Curves from the LTC6652-1.25, LTC6652-2.5 and the LTC6652-5 represent the extremes and typical of the voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 2.5V Output Voltage Temperature Drift 2.5V Line Regulation 2.5V Load Regulation (Sourcing)
2.5010 2.5010 0 3 TYPICAL PARTS –20 –40°C 2.5005 2.5005 –40 –60 2.5000 125°C 25°C TAGE (V) 2.5000 –80 TAGE (V) 125°C 2.4995 25°C –100 TAGE CHANGE (ppm) 2.4995 –120 –40°C 2.4990 OUTPUT VOL –140 REFERENCE VOL 2.4990 –160 2.4985 OUTPUT VOL –180 2.4985 2.4980 –200 –50 –25 0 25 50 75 100 125 150 0 2 4 6 8 10 12 14 0.1 1 10 TEMPERATURE (°C) INPUT VOLTAGE (V) OUTPUT CURRENT (mA) 6652 G01 6652 G02 6652 G03
2.5V Supply Current 2.5V Shutdown Current 2.5V Load Regulation (Sinking) vs Input Voltage vs Input Voltage
700 1000 1.0 900 0.9 600 800 0.8 700 500 0.7 600 0.6 400 500 0.5 TAGE CHANGE (ppm) 125°C 125°C 125°C Y CURRENT (µA) 400 25°C Y CURRENT (µA) 0.4 200 25°C SUPPL 300 0.3 –40°C SUPPL 200 0.2 OUTPUT VOL 100 25°C –40°C 100 0.1 0 0 0 –40°C 0.1 1 10 0 2 4 6 8 10 12 14 0 2 4 6 8 10 12 14 OUTPUT CURRENT (mA) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 6652 G04 6652 G05 6652 G06
2.5V Minimum VIN-VOUT 2.5V Minimum VOUT-VIN Differential (Sourcing) Differential (Sinking)
10 10 1 1 25°C 0.1 25°C OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 125°C, –40°C 125°C –40°C 0.01 0.1 0.001 0.01 0.1 1 0.001 0.01 0.1 1 INPUT-OUTPUT VOLTAGE (V) OUTPUT-INPUT VOLTAGE (V) 6652 G09 6652 G10 6652fg 6 For more information www.linear.com/LTC6652 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
