Datasheet LTC6652 (Analog Devices) - 7
DescriptionPrecision Low Drift Low Noise Buffered Reference
Pages / Page20 / 7 — t ypical perForMance characteristics Characteristic curves are similar …
File Format / SizePDF / 561 Kb
t ypical perForMance characteristics Characteristic curves are similar for most
LTC6652
t ypical perForMance characteristics Characteristic curves are similar for most LTC6652s. Curves from the LTC6652-1.25, LTC6652-2.5 and the LTC6652-5 represent the extremes and typical of the voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 2.5V Low Frequency 0.1Hz to 2.5V Output Voltage Noise 10Hz Transient Noise Spectrum
600 500 ) Hz /√ 400 µV/DIV) TAGE (nV 300 200 OUTPUT NOISE (1 NOISE VOL 100 0 TIME (1 SECOND/DIV) 0.01 0.1 1 10 FREQUENCY (kHz) 6652 G11 6652 G12
Stability with Output Capacitance (LTC6652-2.5, LTC6652-3, Typical VOUT Distribution for LTC6652-3.3, LTC6652-4.096, LTC6652-2.5 LTC6652-5)
180 10µF 1004 UNITS 160 1µF 140 LTC6652A LIMITS 120 0.1µF ACITOR 80 10nF REGION OF 60 MARGINAL STABILITY NUMBER OF UNITS 1nF OUTPUT CAP 40 100pF 20 0 NO CAP 2.4985 2.4995 2.5005 2.5015 –5 0 5 OUTPUT VOLTAGE (V) LOAD CURRENT (mA) 6652 G15 6652 G14 6652fg For more information www.linear.com/LTC6652 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
