Datasheet ADR02ACHIPS (Analog Devices) - 3
DescriptionUltracompact, Precision 5.0 V Voltage Reference
Pages / Page8 / 3 — Data Sheet. ADR02ACHIPS. SPECIFICATIONS. Table 2. Parameter. Symbol. Test …
File Format / SizePDF / 176 Kb
Data Sheet. ADR02ACHIPS. SPECIFICATIONS. Table 2. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADR02ACHIPS SPECIFICATIONS Table 2 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
VIN = 7.0 V to 36.0 V, ILOAD = 0 mA, and 25°C, unless otherwise noted. Due to variations in assembly methods and normal yield loss, yield after packaging is not guaranteed for standard product dice.
Table 2. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
OUTPUT VOLTAGE VO 4.995 5.000 5.005 V Temperature Coefficient TCVO −40°C < TA < +125°C 3 ppm/°C Initial Accuracy VOERR −5 +5 mV REGULATION Line Regulation ΔVO/ΔVIN VIN = 7 V to 36 V 7 30 ppm/V Load Regulation ΔVO/ΔILOAD VIN = 15 V, ILOAD = 0 mA to 10 mA 40 70 ppm/mA DROPOUT VOLTAGE VDO 2 V VOLTAGE NOISE 0.1 Hz to 10.0 Hz eN p-p 10 µV p-p 1 kHz eN 230 nV/√Hz CURRENT Short-Circuit Current ISC 30 mA Quiescent Current IIN 0.65 1 mA TURN-IN SETTLING TIME tR 4 µs LONG-TERM STABILITY ΔVO 1000 hours 50 ppm OUTPUT VOLTAGE HYSTERESIS ΔVO_HYS 75 ppm RIPPLE REJECTION RATIO RRR fIN = 10 kHz −75 dB TEMPERATURE SENSOR Voltage Output at TEMP Pin VTEMP 550 mV Temperature Sensitivity TCVTEMP 1.96 mV/°C Rev. 0 | Page 3 of 8 Document Outline FEATURES GENERAL DESCRIPTION ADR02 CHIP DIMENSIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION OUTLINE DIMENSIONS DIE PAD DESCRIPTIONS ORDERING GUIDE
