Datasheet ADR380, ADR381 (Analog Devices)
Description | 2.048 V and 2.5 V Bandgap Voltage References |
Pages / Page | 16 / 1 — FEATURES. PIN CONFIGURATION. Initial accuracy: ±5 mV/±6 mV maximum. … |
Revision | C |
File Format / Size | PDF / 246 Kb |
FEATURES. PIN CONFIGURATION. Initial accuracy: ±5 mV/±6 mV maximum. Initial accuracy error: ±0.24%/±0.24%. ADR380/. ADR381. Low TCV
Precision Low Drift 2.048 V/2.500 V SOT-23 Voltage Reference ADR380/ADR381
FEATURES PIN CONFIGURATION Initial accuracy: ±5 mV/±6 mV maximum V Initial accuracy error: ±0.24%/±0.24% IN 1 ADR380/ ADR381 Low TCV 3 GND OUT: 25 ppm/°C maximum TOP VIEW Load regulation: 70 ppm/mA
1
V (Not to Scale) OUT 2
-00 75
Line regulation: 25 ppm/V
021
Wide operating ranges
Figure 1. 3-Lead SOT-23
2.4 V to 18 V for ADR380
(RT Suffix)
2.8 V to 18 V for ADR381 Low power: 120 μA maximum High output current: 5 mA Wide temperature range: −40°C to +85°C Tiny 3-lead SOT-23 package with standard pinout APPLICATIONS Battery-powered instrumentation Portable medical instruments Data acquisition systems Industrial process control systems Hard disk drives Automotive GENERAL DESCRIPTION
The ADR380 and ADR381 are precision 2.048 V and 2.500 V
Table 1. ADR38x Products
band gap voltage references featuring high accuracy, high
Part Number Nominal Output Voltage (V)
stability, and low power consumption in a tiny footprint. ADR380 2.048 Patented temperature drift curvature correction techniques ADR381 2.500 minimize nonlinearity of the voltage change with temperature. The wide operating range and low power consumption make them ideal for 3 V to 5 V battery-powered applications. The ADR380 and ADR381 are micropower, low dropout voltage (LDV) devices that provide a stable output voltage from supplies as low as 300 mV above the output voltage. They are specified over the industrial (−40°C to +85°C) temperature range. The ADR380/ADR381 are available in the tiny 3-lead SOT-23 package.
Rev. C Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2001–2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADR380 ELECTRICAL CHARACTERISTICS ADR381 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION DEVICE POWER DISSIPATION CONSIDERATIONS INPUT CAPACITOR OUTPUT CAPACITOR APPLICATIONS INFORMATION STACKING REFERENCE ICs FOR ARBITRARY OUTPUTS A NEGATIVE PRECISION REFERENCE WITHOUT PRECISION RESISTORS PRECISION CURRENT SOURCE PRECISION HIGH CURRENT VOLTAGE SOURCE OUTLINE DIMENSIONS ORDERING GUIDE
