Datasheet ADR380, ADR381 (Analog Devices) - 5
Description2.048 V and 2.5 V Bandgap Voltage References
Pages / Page16 / 5 — THERMAL RESISTANCE. Table 6. Parameter1. Rating. Table 7. Package Type. …
RevisionC
File Format / SizePDF / 246 Kb
THERMAL RESISTANCE. Table 6. Parameter1. Rating. Table 7. Package Type. θJA Unit. ESD CAUTION
THERMAL RESISTANCE Table 6 Parameter1 Rating Table 7 Package Type θJA Unit ESD CAUTION
link to page 5 ADR380/ADR381 ABSOLUTE MAXIMUM RATINGS
THERMAL RESISTANCE Table 6.
θ
Parameter1 Rating
JA is specified for the worst-case conditions, that is, a device soldered in a circuit board for surface-mount packages. Supply Voltage 18 V Output Short-Circuit Duration to GND
Table 7.
VIN > 15 V 10 sec
VIN ≤ 15 V Indefinite 3-Lead SOT-23 (RT) 333 °C/W Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +85°C Junction Temperature Range −65°C to +150°C
ESD CAUTION
Lead Temperature (Soldering, 60 Sec) 300°C 1 Absolute maximum ratings apply at 25°C, unless otherwise noted. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. C | Page 5 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADR380 ELECTRICAL CHARACTERISTICS ADR381 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION DEVICE POWER DISSIPATION CONSIDERATIONS INPUT CAPACITOR OUTPUT CAPACITOR APPLICATIONS INFORMATION STACKING REFERENCE ICs FOR ARBITRARY OUTPUTS A NEGATIVE PRECISION REFERENCE WITHOUT PRECISION RESISTORS PRECISION CURRENT SOURCE PRECISION HIGH CURRENT VOLTAGE SOURCE OUTLINE DIMENSIONS ORDERING GUIDE
