Datasheet LT1027 (Analog Devices) - 2
DescriptionPrecision 5 Volt Reference
Pages / Page8 / 2 — ABSOLUTE. AXI U. R TI GS (Note 1). (OBSOLETE) ... PACKAGE/ORDER I FOR …
File Format / SizePDF / 220 Kb
ABSOLUTE. AXI U. R TI GS (Note 1). (OBSOLETE) ... PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGE. ELECTRICAL CH. ARA TERISTICS The
ABSOLUTE AXI U R TI GS (Note 1) (OBSOLETE) .. PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGE ELECTRICAL CH ARA TERISTICS The
LT1027
W W W U ABSOLUTE AXI U A R TI GS (Note 1)
Supply Voltage (VIN) ... 40V Operating Temperature Range Input-Output Voltage Differential .. 35V LT1027C .. 0°C to 70°C Output to Ground Voltage ... 7V LT1027M
(OBSOLETE) ...
– 55°C to 125°C VTRIM to Ground Voltage Storage Temperature Range Positive .. 5V All Devices ... – 65°C to 150°C Negative .. – 0.3V Lead Temperature (Soldering, 10 sec)... 300°C Output Short-Circuit Duration VIN > 20V .. 10 sec VIN ≤ 20V ... Indefinite
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW NC* TOP VIEW TOP VIEW 8 NC* 1 7 NC* NC* 1 8 NC* NR 1 8 VIN V 2 7 NC* GND 2 7 NC* V IN IN 2 6 VOUT NR 3 6 V V OUT TRIM 3 6 NC* NR 3 5 VTRIM GND 4 5 V V TRIM OUT 4 5 NC* 4 GND N8 PACKAGE S8 PACKAGE H PACKAGE 8-LEAD PDIP 8-LEAD PLASTIC SO 8-LEAD TO-5 METAL CAN TJMAX = 100°C, θJA = 130°C/W TJMAX = 100°C, θJA = 180°C/W TJMAX = 150°C, θJA = 150°C/W, θJC = 45°C/W ORDER PART NUMBER ORDER PART NUMBER ORDER PART NUMBER LT1027ACH-5 LT1027BCN8-5 LT1027CCS8-5 LT1027BCH-5 LT1027CCN8-5 LT1027DCS8-5 LT1027CCH-5 LT1027DCN8-5 LT1027ECS8-5 LT1027DCH-5 LT1027ECN8-5 S8 PART MARKING LT1027ECH-5 1027C5
OBSOLETE PACKAGE
1027D5 Consider the N8 or S8 Packages for Alternate Source 1027E5 *Connected internally. Do not connect external circuitry to these pins. Consult LTC Marketing for parts specified with wider operating temperature ranges.
ELECTRICAL CH C ARA TERISTICS The
denotes specifications which apply over the full operating temperature range otherwise specifications are at TA = 25
C. VIN = 10V, ILOAD = 0, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOUT Output Voltage (Note 2) LT1027A 4.9990 5.000 5.0010 V LT1027B, C, D 4.9975 5.000 5.0025 LT1027E 4.9950 5.000 5.0050 TCVOUT Output Voltage Temperature Coefficient LT1027A, B ● 1 2 ppm/°C (Note 3) LT1027C ● 2 3 LT1027D ● 2 5 LT1027E ● 3 7.5 sn1027 1027fcs 2
