Datasheet REF43 (Analog Devices)
Description | +2.5V Low Power Precision Voltage Reference |
Pages / Page | 12 / 1 — +2.5 V Low Power Precision. Voltage Reference. REF43. FEATURES. PIN … |
Revision | D |
File Format / Size | PDF / 979 Kb |
+2.5 V Low Power Precision. Voltage Reference. REF43. FEATURES. PIN CONFIGURATION. GENERAL DESCRIPTION. ORDERING GUIDE. Number of
![Datasheet REF43 Analog Devices, Revision: D](https://www.rlocman.ru/datasheet/img.php?di=149809)
+2.5 V Low Power Precision Voltage Reference REF43 FEATURES PIN CONFIGURATION GENERAL DESCRIPTION
Tight output tolerances and low thermal drift are assured by The REF43 is a low power precision reference providing a zener-zap trimming of both output voltage and its temperature stable 2.5 V output independent of variations in supply voltage, coefficient. A unique curvature correction circuit reduces the load conditions or ambient temperature. It is suitable as a thermal curvature which is characteristic of many previous reference level for 8-, 10- and 12-bit data acquisition systems, bandgap references. or wherever a stable, known voltage is required.
ORDERING GUIDE Number of Initial Temperature Package Package Part per Temperature Model Accuracy Coefficient Description Option Reel/Tray Range
REF43FZ 0.06% 10ppm/∞C 8-Pin Hermetic DIP Q-8 48 –40∞C to +85∞C REF43GZ 0.10% 25ppm/∞C 8-Pin Hermetic DIP Q-8 48 –40∞C to +85∞C REF43GP 0.10% 25ppm/∞C 8-Pin Plastic DIP N-8 50 –40∞C to +85∞C REF43GS 0.10% 25ppm/∞C 8-Pin SOIC R-8 98 –40∞C to +85∞C REF43GS-REEL 0.10% 25ppm/∞C 8-Pin SOIC R-8 2,500 –40∞C to +85∞C REF43GS-REEL7 0.10% 25ppm/∞C 8-Pin SOIC R-8 1,000 –40∞C to +85∞C REF43GSZ* 0.10% 25ppm/∞C 8-Pin SOIC R-8 98 –40∞C to +85∞C REF43GSZ-REEL7* 0.10% 25ppm/∞C 8-Pin SOIC R-8 1,000 –40∞C to +85∞C REF43NBC 0.20% Die 221 *Z = Pb-free part.
SIMPLIFIED SCHEMATIC VIN VOUT TRIM TEMP
REV. D
GROUND
Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise
under any patent or patent rights of Analog Devices. Trademarks and
Tel: 781/329-4700 www.analog.com
registered trademarks are the property of their respective owners.
Fax: 781/326-8703 © 2004 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES GENERAL DESCRIPTION PIN CONFIGURATION ORDERING GUIDE SIMPLIFIED SCHEMATIC ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS BURN-IN CIRCUIT OUTPUT VOLTAGE TRIM METHOD DICE CHARACTERISTICS WAFER TEST LIMITS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION GENERATING A –2.5V REFERENCE BOOST TRANSISTOR PROVIDES HIGH OUTPUT CURRENT LOW POWER CMOS DAC REFERENCE PRECISION CURRENT SOURCE TEMPERATURE MEASUREMENT OUTLINE DIMENSIONS Revision History
