Datasheet LTM4678 (Analog Devices) - 2
DescriptionDual 25A or Single 50A µModule Regulator with Digital Power System Management
Pages / Page124 / 2 — TABLE OF CONTENTS Features ... 1. Applications .. 1. Typical Application …
File Format / SizePDF / 6.6 Mb
TABLE OF CONTENTS Features ... 1. Applications .. 1. Typical Application .. 1. Description.. 1. Table of Contents .. 2
TABLE OF CONTENTS Features .. 1 Applications . 1 Typical Application . 1 Description. 1 Table of Contents . 2
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 4 link to page 4 link to page 4 link to page 5 link to page 12 link to page 15 link to page 19 link to page 19 link to page 20 link to page 21 link to page 23 link to page 23 link to page 23 link to page 24 link to page 25 link to page 26 link to page 26 link to page 26 link to page 27 link to page 27 link to page 28 link to page 28 link to page 28 link to page 28 link to page 29 link to page 29 link to page 29 link to page 29 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 31 link to page 31 link to page 31 link to page 31 link to page 32 link to page 32 link to page 32 link to page 32 link to page 33 link to page 33 link to page 33 link to page 33 link to page 33 link to page 33 link to page 34 link to page 35 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 37 link to page 37 link to page 38 link to page 38 link to page 38 link to page 38 link to page 38 link to page 38 link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 40 link to page 40 link to page 40 link to page 41 link to page 41 link to page 42 LTM4678
Table 3. FSWPH_CFG Pin Strapping Look-Up
Applications .. 1
Table to Set the LTM4678’s Switching Frequency
and Channel Phase-Interleaving Angle (Not
Description.. 1
Applicable if MFR_CONFIG_ALL[6] = 1b) ..32
Table 4. ASEL Pin Strapping Look-Up Table to
Absolute Maximum Ratings .. 4
Set the LTM4678’s Slave Address (Applicable
Order Information .. 4
Regardless of  MFR_CONFIG_ALL[6] Setting) ..33
Pin Configuration .. 4
Table 5. LTM4678 MFR_ADDRESS Command
Electrical Characteristics ... 5
Examples Expressed in 7- and 8-Bit Addressing .. 33
Typical Performance Characteristics ..12
Fault Detection and Handling ...33
Pin Functions ..15
Status Registers and ALERT Masking ..34
Simplified Block Diagram ...19
Figure 5. LTM4678 Status Register Summary ..35
Decoupling Requirements ...19
Mapping Faults to FAULT Pins ...36
Functional Diagram ..20
Power Good Pins ...36
Test Circuits ...21
CRC Protection ..36
Operation...23
Serial Interface ...36 Power Module Introduction ...23 Communication Protection ..36 Power Module Overview, Major Features ..23 Device Addressing ...36 EEPROM with ECC ... 24 Responses to VOUT and IIN/IOUT Faults ..37 Power-Up and Initialization ..25 Output Overvoltage Fault Response ...37 Soft-Start ...26 Output Undervoltage Response ...38 Time-Based Sequencing ..26 Peak Output Overcurrent Fault Response ..38 Voltage-Based Sequencing ..26 Responses to Timing Faults ...38 Shutdown ..27 Responses to VIN OV Faults ...38 Light-Load Current Operation ..27 Responses to OT/UT Faults ..38 Switching Frequency and Phase ...28 Internal Overtemperature Fault Response ..38 PWM Loop Compensation ...28 External Overtemperature and Output Voltage Sensing ...28 Undertemperature Fault Response ..39 INTVCC/EXTVCC Power ..28 Responses to Input Overcurrent and Output Output Current Sensing and Sub Mil iohm DCR Undercurrent Faults ...39 Current Sensing ...29 Responses to External Faults ...39 Input Current Sensing ..29 Fault Logging ...39 PolyPhase Load Sharing ..29 Bus Timeout Protection ...39 External/Internal Temperature Sense ...30 Similarity Between PMBus, SMBus and I2C RCONFIG (Resistor Configuration) Pins ...30 2-Wire Interface ...40 Table 1. VOUTn _CFG Pin Strapping Look-Up Table PMBus Serial Digital Interface ...40 for the LTM4678’s Output Voltage, Coarse Setting Table 6. Abbreviations of Supported Data Formats ..41 (Not Applicable if MFR_CONFIG_ALL[6] = 1b) ...30 Figure 6. PMBus Timing Diagram ... 41 Table 2. VTRIMn_CFG Pin Strapping Look-Up Figures 7 to 24 PMBus Protocols ...42 Table for the LTM4678’s Output Voltage, Fine Adjustment Setting (Not Applicable if MFR_ CONFIG_ALL[6] = 1b) ..31 Rev 0 2 For more information www.analog.com Document Outline Functional Diagram Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Functional Diagram Test Circuits Operation Power Module Introduction Power Module Overview, Major Features EEPROM with ECC Power-Up and Initialization Soft-Start Time-Based Sequencing Voltage-Based Sequencing Shutdown Light-Load Current Operation Switching Frequency and Phase PWM Loop Compensation Output Voltage Sensing INTVCC/EXTVCC Power Output Current Sensing and Sub Milliohm DCR Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Table 1. VOUTn _CFG Pin Strapping Look-Up Table for the LTM4678’s Output Voltage, Coarse Setting (Not Applicable if MFR_CONFIG_ALL[6] = 1b) Table 2. VTRIMn_CFG Pin Strapping Look-Up Table for the LTM4678’s Output Voltage, Fine Adjustment Setting (Not Applicable if MFR_CONFIG_ALL[6] = 1b) Table 3. FSWPH_CFG Pin Strapping Look-Up Table to Set the LTM4678’s Switching Frequency and Channel Phase-Interleaving Angle (Not Applicable if MFR_CONFIG_ALL[6] = 1b) Table 4. ASEL Pin Strapping Look-Up Table to Set the LTM4678’s Slave Address (Applicable Regardless of MFR_CONFIG_ALL[6] Setting) Table 5. LTM4678 MFR_ADDRESS Command Examples Expressed in 7- and 8-Bit Addressing Fault Detection and Handling Status Registers and ALERT Masking Figure 5. LTM4678 Status Register Summary Mapping Faults to FAULT Pins Power Good Pins CRC Protection Serial Interface Communication Protection Device Addressing Responses to VOUT and IIN/IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault Response External Overtemperature and Undertemperature Fault Response Responses to Input Overcurrent and Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface Table 6. Abbreviations of Supported Data Formats Figure 6. PMBus Timing Diagram Figures 7 to 24 PMBus Protocols PMBus Command Summary PMBus Commands Table 7. PMBus Commands Summary (Note: The Data Format Abbreviations are Detailed in Table 8) Table 8. Data Format Abbreviations Applications Information VIN to VOUT Step-Down Ratios Input Capacitors Output Capacitors Light Load Current Operation Switching Frequency and Phase Output Current Limit Programming Minimum On-Time Considerations Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) Undervoltage Lockout Fault Detection and Handling Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Input Current Sense Amplifier Programmable Loop Compensation Checking Transient Response PolyPhase Configuration Connecting The USB to I2C/SMBus/PMBus Controller to the LTM4678 In System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing Thermal Considerations and Output Current Derating Tables 10 thru 11: Output Current Derating Table 12. Channel Output Voltage vs Component Selection, 0A to 12.5A/μs Load Step Output Capacitor-GRM32ER60G337ME05L, 330μF, 4V, X5R, Murata Table 13. Channel Output Voltage vs Component Selection, 0A to 12.5A/μs Load Step Dual Phase Single Output Voltage vs Component Selection, 25A to 50A/μs Load Step Applications Information-Derating Curves EMI Performance Safety Considerations Layout Checklist/Example Typical Applications PMBus Command Details Addressing and Write Protect General Configuration Commands On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature Power Stage DCR Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status MFR_INFO Data Contents: Telemetry NVM Memory Commands Store/Restore Fault Logging Block Memory Write/Read Package Description Table 22. LTM4678 BGA Pinout Typical Applications Design Resources Related Parts
