Datasheet LTM4678 (Analog Devices) - 3
DescriptionDual 25A or Single 50A µModule Regulator with Digital Power System Management
Pages / Page124 / 3 — TABLE OF CONTENTS PMBus Command Summary ..45. Typical Applications ..72. …
File Format / SizePDF / 6.6 Mb
TABLE OF CONTENTS PMBus Command Summary ..45. Typical Applications ..72. PMBus Command Details ...77
TABLE OF CONTENTS PMBus Command Summary ..45 Typical Applications ..72 PMBus Command Details ...77
link to page 45 link to page 45 link to page 45 link to page 45 link to page 45 link to page 50 link to page 51 link to page 51 link to page 51 link to page 51 link to page 51 link to page 52 link to page 53 link to page 54 link to page 54 link to page 54 link to page 54 link to page 55 link to page 56 link to page 56 link to page 56 link to page 57 link to page 58 link to page 58 link to page 59 link to page 60 link to page 60 link to page 60 link to page 61 link to page 61 link to page 63 link to page 63 link to page 66 link to page 67 link to page 67 link to page 67 link to page 67 link to page 68 link to page 68 link to page 68 link to page 68 link to page 69 link to page 70 link to page 70 link to page 70 link to page 72 link to page 77 link to page 77 link to page 79 link to page 80 link to page 82 link to page 85 link to page 85 link to page 86 link to page 89 link to page 91 link to page 92 link to page 92 link to page 93 link to page 93 link to page 94 link to page 95 link to page 95 link to page 95 link to page 96 link to page 96 link to page 99 link to page 100 link to page 101 link to page 102 link to page 102 link to page 104 link to page 104 link to page 105 link to page 106 link to page 112 link to page 112 link to page 116 link to page 116 link to page 117 link to page 121 link to page 122 link to page 122 link to page 124 link to page 124 link to page 124 LTM4678
PMBus Commands ..45
Table 7. PMBus Commands Summary (Note: Addressing and Write Protect ...77 The Data Format Abbreviations are Detailed in General Configuration Commands ..79 Table 8) ..45 On/Off/Margin ...80 Table 8. Data Format Abbreviations ...50 PWM Configuration ..82
Applications Information ..51
Voltage ..85 VIN to VOUT Step-Down Ratios ...51 Input Voltage and Limits ...85 Input Capacitors .. 51 Output Voltage and Limits ..86 Output Capacitors .. 51 Output Current and Limits ..89 Light Load Current Operation ... 51 Input Current and Limits ..91 Switching Frequency and Phase ..52 Temperature ..92 Output Current Limit Programming ...53 Power Stage DCR Temperature Calibration ...92 Minimum On-Time Considerations ...54 Timing ...93 Variable Delay Time, Soft-Start and Output Timing—On Sequence/Ramp ...93 Voltage Ramping ...54 Timing—Off Sequence/Ramp ..94 Digital Servo Mode ..54 Precondition for Restart ...95 Soft Off (Sequenced Off) ...55 Fault Response ...95 Undervoltage Lockout ..56 Fault Responses Al Faults ..95 Fault Detection and Handling ...56 Fault Responses Input Voltage..96 Open-Drain Pins ...56 Fault Responses Output Voltage ...96 Phase-Locked Loop and Frequency Synchronization .. 57 Fault Responses Output Current ...99 Input Current Sense Amplifier ..58 Fault Responses IC Temperature .. 100 Programmable Loop Compensation ..58 Fault Responses External Temperature ... 101 Checking Transient Response ..59 Fault Sharing ... 102 PolyPhase Configuration ...60 Fault Sharing Propagation .. 102 Connecting The USB to I2C/SMBus/PMBus Fault Sharing Response .. 104 Control er to the LTM4678 In System ..60 Scratchpad .. 104 LTpowerPlay: An Interactive GUI for Digital Power ...61 Identification ... 105 PMBus Communication and Command Processing ...61 Fault Warning and Status .. 106 Thermal Considerations and Output Current MFR_INFO Data Contents: .. 112 Derating ..63 Telemetry .. 112 Tables 10 thru 11: Output Current Derating ...66 NVM Memory Commands .. 116 Table 12. Channel Output Voltage vs Component Store/Restore ... 116 Selection, 0A to 12.5A/μs Load Step .. Fault Logging .. 117 Output Capacitor-GRM32ER60G337ME05L, Block Memory Write/Read .. 121 330μF, 4V, X5R, Murata ..67
Package Description ... 122
Table 13. Channel Output Voltage vs Component Table 22. LTM4678 BGA Pinout .. 122 Selection, 0A to 12.5A/μs Load Step ..68
Package Photograph ... 124
Dual Phase Single Output Voltage vs Component
Design Resources .. 124
Selection, 25A to 50A/μs Load Step ...68
Related Parts .. 124 Applications Information-Derating Curves ..69
EMI Performance ...70 Safety Considerations ..70 Layout Checklist/Example ..70 Rev 0 For more information www.analog.com 3 Document Outline Functional Diagram Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Functional Diagram Test Circuits Operation Power Module Introduction Power Module Overview, Major Features EEPROM with ECC Power-Up and Initialization Soft-Start Time-Based Sequencing Voltage-Based Sequencing Shutdown Light-Load Current Operation Switching Frequency and Phase PWM Loop Compensation Output Voltage Sensing INTVCC/EXTVCC Power Output Current Sensing and Sub Milliohm DCR Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Table 1. VOUTn _CFG Pin Strapping Look-Up Table for the LTM4678’s Output Voltage, Coarse Setting (Not Applicable if MFR_CONFIG_ALL[6] = 1b) Table 2. VTRIMn_CFG Pin Strapping Look-Up Table for the LTM4678’s Output Voltage, Fine Adjustment Setting (Not Applicable if MFR_CONFIG_ALL[6] = 1b) Table 3. FSWPH_CFG Pin Strapping Look-Up Table to Set the LTM4678’s Switching Frequency and Channel Phase-Interleaving Angle (Not Applicable if MFR_CONFIG_ALL[6] = 1b) Table 4. ASEL Pin Strapping Look-Up Table to Set the LTM4678’s Slave Address (Applicable Regardless of MFR_CONFIG_ALL[6] Setting) Table 5. LTM4678 MFR_ADDRESS Command Examples Expressed in 7- and 8-Bit Addressing Fault Detection and Handling Status Registers and ALERT Masking Figure 5. LTM4678 Status Register Summary Mapping Faults to FAULT Pins Power Good Pins CRC Protection Serial Interface Communication Protection Device Addressing Responses to VOUT and IIN/IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault Response External Overtemperature and Undertemperature Fault Response Responses to Input Overcurrent and Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface Table 6. Abbreviations of Supported Data Formats Figure 6. PMBus Timing Diagram Figures 7 to 24 PMBus Protocols PMBus Command Summary PMBus Commands Table 7. PMBus Commands Summary (Note: The Data Format Abbreviations are Detailed in Table 8) Table 8. Data Format Abbreviations Applications Information VIN to VOUT Step-Down Ratios Input Capacitors Output Capacitors Light Load Current Operation Switching Frequency and Phase Output Current Limit Programming Minimum On-Time Considerations Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) Undervoltage Lockout Fault Detection and Handling Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Input Current Sense Amplifier Programmable Loop Compensation Checking Transient Response PolyPhase Configuration Connecting The USB to I2C/SMBus/PMBus Controller to the LTM4678 In System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing Thermal Considerations and Output Current Derating Tables 10 thru 11: Output Current Derating Table 12. Channel Output Voltage vs Component Selection, 0A to 12.5A/μs Load Step Output Capacitor-GRM32ER60G337ME05L, 330μF, 4V, X5R, Murata Table 13. Channel Output Voltage vs Component Selection, 0A to 12.5A/μs Load Step Dual Phase Single Output Voltage vs Component Selection, 25A to 50A/μs Load Step Applications Information-Derating Curves EMI Performance Safety Considerations Layout Checklist/Example Typical Applications PMBus Command Details Addressing and Write Protect General Configuration Commands On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature Power Stage DCR Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status MFR_INFO Data Contents: Telemetry NVM Memory Commands Store/Restore Fault Logging Block Memory Write/Read Package Description Table 22. LTM4678 BGA Pinout Typical Applications Design Resources Related Parts
