Datasheet LTM8001 (Analog Devices) - 4
Description36VIN, 5A μModule Regulator with 5-Output Configurable LDO Array
Pages / Page28 / 4 — e lecTrical characTerisTics The. denotes the specifications which apply …
File Format / SizePDF / 400 Kb
e lecTrical characTerisTics The. denotes the specifications which apply over the full operating
e lecTrical characTerisTics The denotes the specifications which apply over the full operating
LTM8001
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. RUN = 3V unless otherwise noted (Note 3). PARAMETER CONDITIONS MIN TYP MAX UNITS
Maximum VOUT0 to VOUT1-3 and VIN45 to IOUT1-5 = 310mA 15 V VOUT4-5 Differential Voltage (Note 5) IOUT1-5 = 125mA 22 V BIAS123, BIAS45 Pin Current IOUT1-5 = 100mA 6 mA IOUT1-5 = 1.1A l 30 mA VOUT1-5 Current Limit (Note 5) VOUT1-5 = –0.1V 1.3 A VOUT1-5 RMS Output Noise VOUT1-5 = 1V, IOUT1-5 = 1.1A, 100Hz to 1MHz 90 µVRMS
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings –40°C to 125°C internal operating temperature range. The LTM8001MP may cause permanent damage to the device. Exposure to any Absolute is guaranteed to meet specifications over the full –55°C to 125°C internal Maximum Rating condition for extended periods may affect device operating temperature range. Note that the maximum internal temperature reliability and lifetime. is determined by specific operating conditions in conjunction with board
Note 2:
This μModule regulator includes overtemperature protection that layout, the rated package thermal resistance and other environmental is intended to protect the device during momentary overload conditions. factors. Junction temperature will exceed 125°C when overtemperature protection
Note 4:
No minimum load is required if the respective linear regulator is is active. Continuous operation above the specified maximum operating off, such as when VOUT0 = 0V, VIN45 = 0V, BIAS123 = 0V or BIAS45 = 0V. junction temperature may impair device reliability.
Note 5:
The current limit may decrease to zero at input-to-output
Note 3:
The LTM8001E is guaranteed to meet performance specifications differential voltages greater than 22V. Operation at voltages for VOUT0, from 0°C to 125°C internal. Specifications over the full –40°C to VIN45, BIAS123 and BIAS45 is allowed up to a maximum of 25V as long 125°C internal operating temperature range are assured by design, as the difference between the linear regulator input and output voltage characterization and correlation with statistical process controls. The is below the specified differential voltage. Line and load regulation LTM8001I is guaranteed to meet specifications over the full specifications are not applicable when the device is in current limit.
Typical perForMance characTerisTics (TA = 25°C unless otherwise noted. Configured per Table 1, where applicable.) Efficiency vs Output Current, Efficiency vs Output Current, Efficiency vs Output Current, VOUT0 = 2.5V VOUT0 = 3.3V VOUT0 = 5V
90 95 100 85 90 95 80 85 90 75 80 85 70 75 80 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 65 70 75 V V V 60 INO = 12V INO = 12V INO = 12V V 65 70 INO = 24V VINO = 24V VINO = 24V VINO = 36V VINO = 36V VINO = 36V 55 60 65 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 VOUT0 CURRENT (A) VOUT0 CURRENT (A) VOUT0 CURRENT (A) 8001 G01 8001 G02 8001 G03 8001fd 4 For more information www.linear.com/LTM8001 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photo Revision History Typical Application Related Parts
