Datasheet LTM8001 (Analog Devices) - 5
Description | 36VIN, 5A μModule Regulator with 5-Output Configurable LDO Array |
Pages / Page | 28 / 5 — Typical perForMance characTerisTics. (TA = 25°C unless otherwise noted. … |
File Format / Size | PDF / 400 Kb |
Typical perForMance characTerisTics. (TA = 25°C unless otherwise noted. Configured per Table 1, where applicable.)
LTM8001
Typical perForMance characTerisTics (TA = 25°C unless otherwise noted. Configured per Table 1, where applicable.) Efficiency vs Output Current, Efficiency vs Output Current, Efficiency vs Output Current, VOUT0 = 8V VOUT0 = 12V VOUT0 = 18V
100 100 100 95 95 95 90 90 90 85 85 85 EFFICIENCY (%) 80 EFFICIENCY (%) 80 EFFICIENCY (%) 75 V 80 INO = 12V 75 VINO = 24V VINO = 24V VINO = 28V VINO = 36V VINO = 36V VINO = 36V 70 70 75 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 VOUT0 CURRENT (A) VOUT0 CURRENT (A) VOUT0 CURRENT (A) 8001 G04 8001 G05 8001 G06
Efficiency vs Output Current, Input Current vs Output Current, Input Current vs Output Current, VOUT0 = 24V VOUT0 = 2.5V VOUT0 = 3.3V
100 1.5 1.8 VINO = 12V VINO = 12V VINO = 24V 1.6 VINO = 24V 1.2 VINO = 36V VINO = 36V 95 1.4 1.2 0.9 1.0 90 0.8 0.6 EFFICIENCY (%) INPUT CURRENT (A) 0.6 INPUT CURRENT (A) 85 0.3 0.4 VINO = 28V 0.2 VINO = 36V 80 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 VOUT0 CURRENT (A) VOUT0 CURRENT (A) VOUT0 CURRENT (A) 8001 G07 8001 G08 8001 G09
Input Current vs Output Current, Input Current vs Output Current, Input Current vs Output Current, VOUT0 = 5V VOUT0 = 8V VOUT0 = 12V
2.5 4.0 3.0 VINO = 12V VINO = 12V VINO = 24V 3.5 VINO = 24V 2.0 VINO = 36V VINO = 36V 2.5 3.0 2.0 1.5 2.5 2.0 1.5 1.0 1.5 1.0 INPUT CURRENT (A) INPUT CURRENT (A) INPUT CURRENT (A) 1.0 0.5 0.5 0.5 VINO = 24V VINO = 36V 0 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 VOUT0 CURRENT (A) VOUT0 CURRENT (A) VOUT0 CURRENT (A) 8001 G10 8001 G11 8001 G12 8001fd For more information www.linear.com/LTM8001 5 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photo Revision History Typical Application Related Parts
