Datasheet LTM4639 (Analog Devices) - 3
Description | Low VIN 20A DC/DC μModule (Power Module) Step-Down Regulator |
Pages / Page | 32 / 3 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply … |
File Format / Size | PDF / 588 Kb |
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the specified internal
LTM4639
denotes the specifications which apply over the specified internal operating temperature range (Note 2), otherwise specifications are at TA = 25°C. VIN = 3.3V, CPWR = 5V, per the typical application in Figure 22. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input Specifications
VRUN RUN Pin On Threshold VRUN Rising 1.1 1.25 1.4 V VRUNHYS RUN Pin On Hysteresis 130 mV IQ(VIN) Input Supply Bias Current VIN = 7V, VOUT = 1.5V, Burst Mode Operation, IOUT = 0.1A 25 mA VIN = 7V, VOUT = 1.5V, Pulse-Skipping Mode, IOUT = 0.1A 35 mA VIN = 7V, VOUT = 1.5V, Switching Continuous, IOUT = 0.1A 68 mA Shutdown, RUN = 0, VIN = CPWR = 7V 45 µA IS(VIN) Input Supply Current VIN = 3.3V, VOUT = 1.5V, IOUT = 20A, CPWR = 5V 10.35 A VIN = 7V, VOUT = 1.5V, IOUT = 20A, CPWR = 5V 4.93 A IPWR(IN) Control Power Current 3.3VIN to 1.5VOUT at 0A Load, CPWR = 5V 28 mA
Output Specifications
IOUT(DC) Output Continuous Current VIN = 3.3V, VOUT = 1.5V (Note 4) 0 20 A Range ∆VOUT (Line) Line Regulation Accuracy VOUT = 1.5V, VIN from 2.375V to 7V, CPWR = 5V, l 0.02 0.04 %/V VOUT IOUT = 0A ∆VOUT (Load) Load Regulation Accuracy VOUT = 1.5V, IOUT = 0A to 20A, VIN = 3.3V, CPWR = 5V l 0.1 0.3 % VOUT (Note 4) VOUT(AC) Output Ripple Voltage IOUT = 0A, COUT = 100µF Ceramic, 470µF POSCAP 20 mVP-P VIN = 3.3V, VOUT = 1.5V, CPWR = 5V ∆VOUT(START) Turn-On Overshoot COUT = 100µF Ceramic, 470µF POSCAP, 15 mV VOUT = 1.5V, IOUT = 0A, VIN = 3.3V, CPWR = 5V tSTART Turn-On Time COUT = 100µF Ceramic, 470µF POSCAP, 0.6 ms No Load, TRACK/SS = 0.001µF, VIN = 3.3V, CPWR = 5V ∆VOUTLS Peak Deviation for Load: 5A to 12.5A Load Step, 1µs Rise Time 30 mV Dynamic Load COUT = 100µF × 2 Ceramic, COUT × 2 POSCAP, VIN = 3.3V, VOUT = 1.5V, CPWR = 5V tSETTLE Settling Time for Dynamic Load: 5A to 12.5A Load Step, 3.3V, VIN = 5V, VOUT = 1.5V 30 µs Load Step COUT = 100µF × 2 Ceramic, 680µF POSCAP IOUTPK Output Current Limit VIN = 3.3V, VOUT = 1.5V 30 A VIN = 7V, VOUT = 1.5V 30 A
Control Section
VFB Voltage at VFB Pin IOUT = 0A, VOUT = 1.5V l 0.594 0.60 0.606 V IFB Current at VFB Pin (Note 7) –12 –25 nA VOVL Feedback Overvoltage l 0.65 0.67 0.69 V Lockout ITRACK/SS Track Pin Soft-Start Pull- TRACK/SS = 0V 1.0 1.2 1.4 µA Up Current tON(MIN) Minimum On-Time (Note 3) 100 ns RFBHI Resistor Between VOUT_LCL 60.05 60.40 60.75 kΩ and VFB Pins
Remote Sense Amplifier
V + OSNS , Common Mode Input VIN = 3.3V, Run > 1.4V, CPWR = 5V 0 3.6 V VOSNS– CM RANGE Range VDIFF_OUT(MAX) Maximum DIFF_OUT IDIFF_OUT = 300µA INTVCC – 1.4 V Voltage V + OS Input Offset Voltage VOSNS = VDIFF_OUT = 1.5V, IDIFF_OUT = 100µA 2.5 mV 4639f For more information www.linear.com/LTM4639 3
