Datasheet LTM8026 (Analog Devices) - 8
Description | 36VIN, 5A CVCC Step-Down µModule Regulator |
Pages / Page | 28 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 432 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, unless otherwise noted. Configured per Table 1, where applicable
LTM8026
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Configured per Table 1, where applicable. Minimum Required Input Voltage Minimum Required Input Voltage Minimum Required Input Voltage vs Load 24VOUT vs Load –3.3VOUT vs Load –5VOUT
28.0 35 35 TO START TO START 30 RUN CONTROLLED 30 RUN CONTROLLED 27.5 TO RUN TO RUN 25 25 27.0 20 20 26.5 15 15 INPUT VOLTAGE (V) INPUT VOLTAGE (V) 10 INPUT VOLTAGE (V) 10 26.0 5 5 25.5 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 LOAD CURRENT (A) LOAD CURRENT (A) LOAD CURRENT (A) 8026 G37 8026 G38 8026 G39
Minimum Required Input Voltage Minimum Required Input Voltage Temperature Rise vs Load Current vs Load –8VOUT vs Load –12VOUT 2.5VOUT
30 30 60 TO START TO START 36VIN RUN CONTROLLED RUN CONTROLLED 24VIN 25 TO RUN 25 TO RUN 50 12VIN 6VIN 20 20 40 15 15 30 10 INPUT VOLTAGE (V) 10 INPUT VOLTAGE (V) 20 TEMPERATURE RISE (°C) 5 5 10 0 0 0 0 1 2 3 4 5 0 1 2 3 4 0 1 2 3 4 5 LOAD CURRENT (A) LOAD CURRENT (A) LOAD CURRENT (A) 8026 G40 8026 G41 8026 G42
Temperature Rise vs Load Current Temperature Rise vs Load Current Temperature Rise vs Load Current 3.3VOUT 5VOUT 8VOUT
60 70 90 36VIN 36VIN 36VIN 24VIN 24VIN 80 24VIN 50 12V 60 IN 12VIN 12VIN 6VIN 7VIN 70 50 40 60 40 50 30 30 40 20 30 20 TEMPERATURE RISE (°C) TEMPERATURE RISE (°C) TEMPERATURE RISE (°C) 20 10 10 10 0 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 LOAD CURRENT (A) LOAD CURRENT (A) LOAD CURRENT (A) 8026 G43 8026 G44 8026 G45 8026fd 8 For more information www.linear.com/LTM8026 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photo Package Description Revision History Typical Application Design Resources Related Parts
