Datasheet LTM8032 (Analog Devices) - 3
DescriptionEN55022B Compliant 36V, 2A DC/DC µModule
Pages / Page26 / 3 — e lecTrical characTerisTics The. denotes the specifications which apply …
File Format / SizePDF / 532 Kb
e lecTrical characTerisTics The. denotes the specifications which apply over the full internal operating
e lecTrical characTerisTics The denotes the specifications which apply over the full internal operating
LTM8032
denotes the specifications which apply over the full internal operating temperature range, otherwise specifications are at TA = 25°C. VIN = 10V, VRUN/SS = 10V, VBIAS = 3V, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Input DC Voltage l 3.6 36 V VOUT Output DC Voltage 0.2A < IOUT ≤ 2A, RADJ Open 0.8 V 0.2A < IOUT ≤ 2A, RADJ = 21.6k 10 V IOUT Continuous Output DC Current VIN = 24V 2 A IQ(VIN) VIN Quiescent Current VRUN/SS = 0.2V 0.6 µA VBIAS = 3V, Not Switching l 25 60 µA VBIAS = 0V, Not Switching 88 120 µA IQ(BIAS) BIAS Quiescent Current VRUN/SS = 0.2V 0.03 µA VBIAS = 3V, Not Switching l 60 120 µA VBIAS = 0V, Not Switching 1 5 µA ∆VOUT Line Regulation 10V ≤ VIN ≤ 36V, IOUT = 1A, VOUT = 3.3V 0.1 % VOUT Load Regulation VIN = 24V, 0.2A ≤ IOUT ≤ 2A, VOUT = 3.3V 0.3 % VOUT(AC_RMS) Output Ripple (RMS) VIN = 24V, IOUT = 2A, VOUT = 3.3V 6 mV fSW Switching Frequency RT = 113k 325 kHz VADJ Voltage at ADJ Pin l 765 790 815 mV VBIAS(MIN) Minimum BIAS Voltage for Proper Operation 1.9 2.8 V IADJ Current Out of ADJ Pin VRUN/SS = 0V, VADJ = 0V, VOUT = 1V 4 µA IRUN/SS RUN/SS Pin Current VRUN/SS = 2.5V 5 10 µA VIH(RUN/SS) RUN/SS Input High Voltage 2.5 V VIL(RUN/SS) RUN/SS Input Low Voltage 0.2 V VPG(TH) ADJ Voltage Threshold for PGOOD to Switch 730 mV IPGO PGOOD Leakage VPG = 30V 0.1 1 µA IPGSINK PGOOD Sink Current VPG = 0.4V 200 800 µA VSYNCIL SYNC Input Low Threshold fSYNC = 550kHz 0.5 V VSYNCIH SYNC Input High Threshold fSYNC = 550kHz 0.7 V ISYNC(BIAS) SYNC Pin Bias Current VSYNC = 0V, VBIAS = 0V 0.1 µA VIN(RIPPLE) 550kHz Narrowband Conducted Emission VIN = 24V, VOUT = 3.3V, IOUT = 2A, fSW = 550kHz, 89 dBµV 1MHz Narrowband Conducted Emission 5µH LISN 69 dBµV 3MHz Narrowband Conducted Emission 51 dBµV
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings correlation with statistical process controls. LTM8032I is guaranteed may cause permanent damage to the device. Exposure to any Absolute to meet specifications over the full –40°C to 125°C internal operating Maximum Rating condition for extended periods may affect device temperature range. The LTM8032MP is guaranteed to meet specifications reliability and lifetime. over the full –55°C to 125°C internal operating temperature range. Note
Note 2:
The LTM8032E is guaranteed to meet performance specifications that the maximum internal temperature is determined by specific operating from 0°C to 125°C internal. Specifications over the –40°C to 125°C conditions in conjunction with board layout, the rated package thermal internal temperature range are assured by design, characterization and resistance and other environmental factors. 8032fg For more information www.linear.com/LTM8032 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Package Photographs Related Parts
