Datasheet LTM8020 (Analog Devices) - 4
Description | 200mA, 36V DC/DC µModule Regulator |
Pages / Page | 16 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C unless otherwise noted. … |
File Format / Size | PDF / 406 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C unless otherwise noted. Input Current vs Output Current. 5VOUT Power Loss
LTM8020
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C unless otherwise noted. Input Current vs Output Current Input Current vs Output Current 5VOUT Power Loss (5VIN) (12VIN)
1000 0.18 0.120 1.8VOUT 1.8VOUT 0.16 2.5VOUT 2.5VOUT 3.3VOUT 0.100 3.3VOUT 0.14 100 5VOUT 0.12 0.080 0.10 10 0.060 0.08 0.06 POWER LOSS (mW) INPUT CURRENT (A) INPUT CURRENT (A) 0.040 1 0.04 12VIN 0.020 24V 0.02 IN 36VIN 0.1 0 0 0.1 1 10 100 1000 0 0.05 0.10 0.15 0.20 0 0.05 0.10 0.15 0.20 IOUT (mA) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8020 G04 4356 G05 4356 G06
Input Current vs Output Current Input Current vs Output Current Input Quiescent Current vs Input (24VIN) (36VIN) Voltage
0.060 0.045 5 1.8VOUT 1.8VOUT 2.5VOUT 0.040 2.5VOUT 0.050 3.3VOUT 3.3VOUT 5V 4 OUT 0.035 5VOUT 0.040 0.030 3 0.025 0.030 0.020 2 INPUT CURRENT (A) 0.020 INPUT CURRENT (A) 0.015 0.010 QUIESCENT CURRENT (µA) 1 0.010 0.005 0 0 0 0 0.05 0.10 0.15 0.20 0 0.05 0.10 0.15 0.20 0 10 20 30 40 OUTPUT CURRENT (A) OUTPUT CURRENT (A) INPUT VOLTAGE (V) 4356 G07 4356 G08 4356 G09
Input Current vs Input Voltage Minimum Required Input Voltage Minimum Required Input Voltage (Output Short) vs Load (VOUT = 3.3V) vs Output Voltage
100 6.0 8 I TO START OUT = 200mA TO START 5.5 7 80 5.0 SHDN CONTROL 6 60 TAGE (V) TAGE (V) TO RUN 4.5 5 40 INPUT VOL 4.0 TO RUN INPUT VOL 4 INPUT CURRENT (mA) 20 3.5 3 0 3.0 2 0 10 20 30 40 0 50 100 150 200 1 2 3 4 5 INPUT VOLTAGE (V) LOAD CURRENT (mA) OUTPUT VOLTAGE (V) 4356 G10 4356 G11 4356 G12 8020fe 4 For more information www.linear.com/LTM8020
