LTM8022 ABSOLUTE MAXIMUM RATINGSPIN CONFIGURATION(Note 1)(See Table 3, Pin Assignment) V GND (BANK 3) SHARE R ADJ IN, RUN/SS Voltage ...40V T ADJ, RT, SHARE, Voltage ..5V 7 V SYNC OUT , AUX ...10V SYNC, PG ..30V 6 PG BIAS ..16V 5 RUN/SS V BIAS IN + BIAS ...56V 4 Internal Operating Temperature..–40°C to 125°C AUX Solder Temperature ... 250°C 3 V Storage Temperature ..–55°C to 125°C OUT (BANK 2) 2 VIN (BANK 1) 1 A B C D E F G H LGA PACKAGE 50-LEAD (11.25mm s 9mm s 2.82mm) TJMAX = 125°C, θJA = 23.4°C/W, θJC(BOTTOM) = 9.20°C/W, θJC(TOP) = 25.10°C/W, θJBOARD = 16°C/W θ VALUES DETERMINED PER JESD51-9 WEIGHT = 0.93g ORDER INFORMATIONLEAD FREE FINISHPART MARKING*PACKAGE DESCRIPTIONTEMPERATURE RANGE (Note 2) LTM8022EV#PBF LTM8022V 50-Pin (11.25mm × 9mm × 2.82mm) LGA –40°C to 85°C LTM8022IV#PBF LTM8022V 50-Pin (11.25mm × 9mm × 2.82mm) LGA –40°C to 85°C LTM8022MPV#PBF LTM8022MPV 50-Pin (11.25mm × 9mm × 2.82mm) LGA –55°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ This product is only offered in trays. For more information go to: http://linear.com/packaging/ 8022fd 2
