Datasheet LT4363 (Analog Devices) - 5
Description | High Voltage Surge Stopper with Current Limit |
Pages / Page | 24 / 5 — Typical perForMance characTerisTics Specifications are at VCC = 12V, TA = … |
File Format / Size | PDF / 255 Kb |
Typical perForMance characTerisTics Specifications are at VCC = 12V, TA = 25°C, unless. otherwise noted
LT4363
Typical perForMance characTerisTics Specifications are at VCC = 12V, TA = 25°C, unless otherwise noted. Supply Current During Shutdown Supply Current During Shutdown Supply Current vs Supply Voltage vs Temperature vs Supply Voltage (ICC vs VCC) (ICC(SHDN) vs Temperature) (ICC(SHDN) vs VCC)
1000 8 6 OUT = SNS = 0V OUT = SNS = 0V 7 5 800 6 4 600 5 (µA) (µA) 4 (µA) 3 I CC I CC I CC 400 3 2 2 200 1 1 0 0 0 0 10 20 30 40 50 60 70 80 –50 –25 0 25 50 75 100 125 0 10 20 30 40 50 60 70 80 VCC (V) TEMPERATURE (°C) VCC (V) 4363 G01 4363 G02 4363 G03
GATE Pull-Up Current vs SHDN Current vs Temperature GATE Pull-Up Current vs VCC Temperature
3.0 –50 –35 2.5 SHDN = 0V –40 –30 2.0 SHDN = 0.4V –30 (µA) (µA) (µA) 1.5 –25 TE(UP) –20 TE(UP) I CC(SHDN) I GA 1.0 I GA –10 –20 0.5 0 0 –15 –50 –25 0 25 50 75 100 125 0 10 20 30 40 50 60 70 80 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) VCC (V) TEMPERATURE (°C) 4363 G04 4363 G05 4363 G06
GATE Pull-Down Current vs GATE Pull-Down Current vs Gate Drive Voltage vs Gate Temperature: Overcurrent Temperature: Overvoltage Pull-Down Current ΔVGATE vs IGATE
200 200 14 VCC = SNS = OUT 175 175 150 150 13 125 125 (mA) (mA) (V) 100 100 TE 12 GA TE(DN,OC) 75 TE(DN,OV) 75 ∆V I GA I GA 50 50 11 ∆V SNS = OUT = 5V 25 SNS = 150mV OUT = 0V 25 GATE = 12V GATE = 10V FB = 1.5V 0 0 10 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 0 –2 –4 –6 –8 –10 TEMPERATURE (°C) TEMPERATURE (°C) IGATE (µA) 4363 G07 4363 G08 4363 G09 4363fb For more information www.linear.com/LT4363 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
