Datasheet LTC4015 (Analog Devices) - 16
DescriptionMultichemistry Buck Battery Charger Controller with Digital Telemetry System
Pages / Page76 / 16 — I2C TIMING DIAGRAM. I2C SMBus Legend. SMBus WRITE WORD PROTOCOL. SMBus …
I2C TIMING DIAGRAM. I2C SMBus Legend. SMBus WRITE WORD PROTOCOL. SMBus WRITE WORD WITH PEC PROTOCOL. SMBus READ WORD PROTOCOL
I2C TIMING DIAGRAM I2C SMBus Legend SMBus WRITE WORD PROTOCOL SMBus WRITE WORD WITH PEC PROTOCOL SMBus READ WORD PROTOCOL
LTC4015
I2C TIMING DIAGRAM
SDA tSU(DAT) tBUF t t t HD(DAT) SU(STA) LOW t t HD(STA) SU(STO) SCL tHD(STA) tf tf tSP tHIGH START REPEATED START STOP START CONDITION CONDITION CONDITION CONDITION 4015 TD
I2C SMBus Legend
S START CONDITION Sr REPEATED START CONDITION Rd READ (BIT VALUE OF 1) Wr WRITE (BIT VALUE OF 0) A ACKNOWLEDGE N NACK P STOP CONDITION PEC* PACKET ERROR CODE MASTER TO SLAVE SLAVE TO MASTER
S SLAVE ADDRESS Wr A COMMAND CODE A DATA BYTE LOW A DATA BYTE HIGH A P
S SLAVE ADDRESS Wr A COMMAND CODE A DATA BYTE LOW A DATA BYTE HIGH A PEC* A P
S SLAVE ADDRESS Wr A COMMAND CODE A Sr SLAVE ADDRESS Rd A DATA BYTE LOW A DATA BYTE HIGH N P
SMBus READ WORD WITH PEC PROTOCOL
S SLAVE ADDRESS Wr A COMMAND CODE A Sr SLAVE ADDRESS Rd A DATA BYTE LOW A DATA BYTE HIGH A PEC* N P
SMBus ALERT RESPONSE ADDRESS PROTOCOL
S ALERT RESPONSE ADDRESS Rd A DEVICE ADDRESS Rd N P
SMBus ALERT RESPONSE ADDRESS PROTOCOL WITH PEC
S ALERT RESPONSE ADDRESS Rd A DEVICE ADDRESS Rd A PEC* N P *USE OF PACKET ERROR CHECKING IS OPTIONAL 4015fb 16 For more information www.linear.com/LTC4015 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Data Sheet Conventions Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram I2C Timing Diagram Operation Applications Information Register Description DETAILED Register Descriptions Typical Applications Package Description Revision History Typical Application Related Parts
