Datasheet LT3796, LT3796-1 (Analog Devices) - 5
Description100V Constant-Current and Constant-Voltage Controller with Dual Current Sense
Pages / Page36 / 5 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 522 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
LT3796/LT3796-1
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C, VIN = 24V, EN/UVLO = 24V, CTRL = 2V, PWM = 5V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS Gate Driver
tr NMOS GATE Driver Output Rise Time CL = 3300pF, 10% to 90% 20 ns tf NMOS GATE Driver Output Fall Time CL = 3300pF, 10% to 90% 18 ns NMOS GATE Output Low (VOL) 0.05 V NMOS GATE Output High (VOH) INTVCC – V 0.05 tr Top GATE Driver Output Rise Time CL = 300pF 50 ns tf Top GATE Driver Output Fall Time CL = 300pF 100 ns Top Gate On Voltage (VISP-VTG) ISP = 48V 7 8 V Top Gate Off Voltage (VISP-VTG) PWM = 0V, ISP = 48V 0 0.3 V
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings correlation with statistical process controls. The LT3796I and LT3796I-1 may cause permanent damage to the device. Exposure to any Absolute are guaranteed to meet performance specifications over the –40°C to Maximum Rating condition for extended periods may affect device 125°C operating temperature range. The LT3796H and LT3796H-1 are reliability and lifetime. guaranteed over the full –40°C to 150° C operating junction temperature
Note 2:
Do not apply a positive or negative voltage source to TG and GATE range. High junction temperatures degrade operating lifetimes. Operating pins, otherwise permanent damage may occur. lifetime is derated at junction temperatures greater than 125°C.
Note 3:
Operating maximum for INTV
Note 5:
Measured in servo. See Figure 9 for details. CC is 8V.
Note 4:
The LT3796E and LT3796E-1 are guaranteed to meet specified
Note 6:
See Duty Cycle Considerations in the Applications Information performance from 0°C to 125°C. Specifications over the –40°C to 125°C section. operating temperature range are assured by design, characterization and 3796fb For more information www.linear.com/3796 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
