Datasheet LTC4001-1 (Analog Devices) - 2
Description2A Synchronous Buck Li-Ion Charger
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 236 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC4001-1
PV TOP VIEW IN, VINSENSE t < 1ms, DC < 1% .. –0.3V to 7V TSENS Steady State ... –0.3V to 6V BA TIMER SS IDET 16 15 14 13 SW, SENSE, BAT, BATSENS, SS, FAULT, CHRG, EN, NTC, BAT 1 12 PROG PROG, IDET, TIMER Voltage .. – 0.3V to 6V SENSE 2 11 NTC Operating Temperature Range (Note 3) .. –40°C to 85°C 17 PGND 3 10 FAULT Operating Junction Temperature GNDSENS 4 9 VINSENSE (Note 5) .. –40°C to 125°C 5 6 7 8 Storage Temperature Range .. –65°C to 125°C IN SW EN CHRG PV UF PACKAGE 16-LEAD (4mm × 4mm) PLASTIC QFN TJMAX = 125°C, θJA = 37°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC4001EUF-1#PBF LTC4001EUF-1#TRPBF 40011 16-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 5V, VEN = 0V, RPROG = 549Ω, RIDET = 549Ω, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Supply Voltage (Note 2) 4 5.5 V IIN PVIN Connected to VINSENSE, PROG and IDET 2 mA Pins Open, Charger On Shutdown, EN = VIN 50 μA VFLOAT VBAT Regulated Float Voltage Measured from BATSENS to GNDSENS ● 4.059 4.1 4.141 V 4.079 4.1 4.121 V IBAT Current Mode Charge Current RPROG = 549Ω, VBAT = 3.5V 1.8 2 2.2 A RPROG = 1.10k, VBAT = 3.5V 0.9 1 1.1 A Shutdown, EN = VIN ±5 μA ITRIKL Trickle Charge Current VBAT = 2V 35 50 65 mA VTRIKL Trickle Charge Threshold VBAT Rising 3.05 3.1 3.20 V VBAT Falling 2.85 3.0 3.05 V VUVL VIN Undervoltage Lockout Voltage VIN Rising, Measured from VINSENSE to GNDSENS 2.7 2.82 V ΔVUVL VIN Undervoltage Lockout Measured from VINSENSE to GNDSENS 100 mV Hysteresis VASD Automatic Shutdown Threshold VINSENSE – VBATSENS Rising (Turn-On), VBATSENSE = 4V 200 250 300 mV Voltage VINSENSE – VBATSENS Falling (Turn-Off), VBATSENSE = 4V 15 30 60 mV 40011fa 2
