Datasheet LTC4001-1 (Analog Devices) - 10
Description2A Synchronous Buck Li-Ion Charger
Pages / Page20 / 10 — APPLICATIONS INFORMATION. Soft-Start and Compensation Capacitor …
File Format / SizePDF / 236 Kb
APPLICATIONS INFORMATION. Soft-Start and Compensation Capacitor Selection. Charge Current and IDET Programming
APPLICATIONS INFORMATION Soft-Start and Compensation Capacitor Selection Charge Current and IDET Programming
LTC4001-1
The IDET threshold (a charge current threshold used to The LTC4001-1 has a low current trickle charger and a determine when the battery is nearly fully charged) is PWM-based high current charger. Soft-start is used when- programmed in much the same way as the PROG pin, ever the high rate charger is initially turned on, preventing except that the IDET threshold is 91.5 times the current high start-up current. Soft-start ramp rate is set by the delivered by the IDET pin. This current is usually set with internal 12.8μA pull-up current and an external capacitor. an external resistor from IDET to ground, but it may also The control range on the SS pin is approximately 0.3V be set with a current output DAC. The voltage on the PROG to 1.6V. With a 0.1μF capacitor, the time to ramp up to pin is nominally 1.213V. maximum duty cycle is approximately 10ms. For 200mA IDET current (corresponding to C/10 for a The external capacitor on the SS pin also sets the compensa- 2AHr battery): tion for the current control loop and the fl oat voltage control R 554.9 loop. A minimum capacitance of 10nF is required. IDET = 91.5 • 1.213V 0.2A
1.10kΩ programs approximately 100mA and 274Ω ap- The LTC4001-1 has two different charge modes. If the proximately 400mA. battery is severely depleted (battery voltage less than For applications where IDET is set to one tenth of the high 2.9V) a 50mA trickle current is initially used. If the battery rate charge current, and slightly poorer charger current voltage is greater than the trickle charge threshold, high and IDET threshold accuracy is acceptable, the PROG and rate charging is used. IDET pins may be tied together and a single resistor, R1, This higher charge current is programmable and is ap- can program both (Figure 1). proximately 915 times the current delivered by the PROG pin. This current is usually set with an external resistor R1= 457.5 • 1.213 I from PROG to GNDSENS, but it may also be set with a CHARGE current output DAC connected to the PROG pin. The volt- and age on the PROG pin is nominally 1.213V. For 2A charge current: IDET = ICHARGE 10 RPROG = 915 •1.213V 554.9 2A LTC4001-1 PROG IDET R1 274Ω FOR 2A GNDSENS 40011 F01
Figure 1. Programming Charge Current and IDET Threshold with a Single Resistor
40011fa 10
