Datasheet LTC4100 (Analog Devices) - 6
Description | Smart Battery Charger Controller |
Pages / Page | 30 / 6 — Typical perForMance characTerisTics. INFET Response Time to. Reverse … |
File Format / Size | PDF / 328 Kb |
Typical perForMance characTerisTics. INFET Response Time to. Reverse Current. VOUT vs IOUT. PWM Frequency vs Duty Cycle
LTC4100
Typical perForMance characTerisTics INFET Response Time to Reverse Current VOUT vs IOUT PWM Frequency vs Duty Cycle
0 350 Vgs OF PFET (2V/DIV) V –0.5 gs = 0 300 –1.0 –1.5 250 V –2.0 s OF PFET (5V/DIV) 200 –2.5 TAGE ERROR (%) –3.0 150 PROGRAMMED CURRENT = 10% –3.5 100 Vs = 0V PWM FREQUENCY (kHz) –4.0 I OUTPUT VOL d (REVERSE) OF 50 DCIN = 15V PFET (5A/DIV) –4.5 DCIN = 20V DCIN = 20V V I BAT = 12.6V DCIN = 24V d = 0A –5.0 0 1.25µs/DIV 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 TEST PERFORMED ON DEMOBOARD OUTPUT CURRENT (A) DUTY CYCLE (VOUT/VIN) VIN = 15VDC VCHARGE = 12.6V 4100 G02 4100 G03 CHARGER = ON INFET = 1/2 Si4925DY ICHARGE = <10mA 4100 G01
Disconnect/Reconnect Battery Battery Leakage Current (Load Dump) vs Battery Voltage Efficiency at 19V VDCIN
40 100 VDCIN = 0V 3A STEP 35 16.8V 95 30 1A STEP 12.6V 1A STEP VFLOAT 25 1V/(DIV) 90 20 15 85 EFFICIENCY (%) 3A STEP Y LEAKAGE CURRENT (µA) LOAD 10 STATE DISCONNECT RECONNECT TTER 80 BA 5 0 75 LOAD CURRENT = 1A, 2A, 3A 0 5 10 15 20 25 30 0.50 1.00 1.50 2.00 2.50 3.00 DCIN = 20V BATTERY VOLTAGE (V) CHARGING CURRENT (A) VFLOAT = 12.6V 4100 G05 4100 G06 4100 G04
Efficiency at 12.6V with 15V VDCIN SMBus Accelerator Operation Low Current Operation
100 0.5 VDD = 5V VDD = 5V 5V CBUS = 200pF TEMP = 27°C T DCIN = 15V 95 A = 25°C 0.4 0.3 90 LTC4100 NO LOW CURRENT 0.2 MODE PROGRAMMED 85 R CURRENT EFFICIENCY (%) PULLUP = 15k 0.1 LOW 0V CURRENT 80 MEASURED CURRENT (A) MODE 0 75 –0.1 0.50 1.00 1.50 2.00 2.50 3.00 0 0.1 0.2 0.3 0.4 CHARGING CURRENT (A) 1µs/DIV PROGRAMMED CURRENT (A) 4100 G07 4100 G08 4100 G09 4100fc 6 For more information www.linear.com/LTC4100
