Datasheet ADE7880 (Analog Devices) - 2
DescriptionPolyphase Multifunction Energy Metering IC with Harmonic Monitoring
Pages / Page107 / 2 — ADE7880. Data Sheet. TABLE OF CONTENTS
RevisionC
ADE7880 Data Sheet TABLE OF CONTENTS
link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 5 link to page 8 link to page 11 link to page 11 link to page 11 link to page 12 link to page 14 link to page 19 link to page 20 link to page 21 link to page 21 link to page 21 link to page 21 link to page 22 link to page 24 link to page 25 link to page 25 link to page 26 link to page 26 link to page 26 link to page 27 link to page 29 link to page 30 link to page 31 link to page 32 link to page 37 link to page 39 link to page 39 link to page 41 link to page 45 link to page 51 link to page 55 link to page 58 link to page 58 link to page 66 link to page 66 link to page 71 link to page 73 link to page 74 link to page 75 link to page 82 link to page 83 link to page 84 link to page 84 link to page 84 link to page 85 link to page 85 link to page 85 link to page 86 link to page 87 link to page 107 link to page 107
Features .. 1 Power Quality Measurements ... 32 Applications ... 1 Phase Compensation ... 37 General Description ... 1 Reference Circuit .. 39 Revision History ... 3 Digital Signal Processor ... 39 Functional Block Diagram .. 4 Root Mean Square Measurement ... 41 Specifications ... 5 Active Power Calculation .. 45 Timing Characteristics .. 8 Fundamental Reactive Power Calculation .. 51 Absolute Maximum Ratings .. 11 Apparent Power Calculation ... 55 Thermal Resistance .. 11 Power Factor Calculation .. 58 ESD Caution .. 11 Harmonics Calculations .. 58 Pin Configuration and Function Descriptions ... 12 Waveform Sampling Mode ... 66 Typical Performance Characteristics ... 14 Energy-to-Frequency Conversion.. 66 Test Circuit .. 19 No Load Condition .. 71 Terminology .. 20 Checksum Register... 73 Power Management .. 21 Interrupts ... 74 PSM0—Normal Power Mode (All Parts) .. 21 Serial Interfaces .. 75 PSM1—Reduced Power Mode.. 21 ADE7880 Quick Setup As Energy Meter .. 82 PSM2—Low Power Mode ... 21 Layout Guidelines... 83 PSM3—Sleep Mode (All Parts) .. 22 Crystal Circuit .. 84 Power-Up Procedure .. 24 ADE7880 Evaluation Board .. 84 Hardware Reset ... 25 Die Version .. 84 Software Reset Functionality .. 25 Silicon Anomaly ... 85 Theory of Operation .. 26 ADE7880 Functionality Issues ... 85 Analog Inputs .. 26 Functionality Issues .. 85 Analog-to-Digital Conversion .. 26 Section 1. ADE7880 Functionality Issues ... 86 Current Channel ADC... 27 Registers List ... 87 di/dt Current Sensor and Digital Integrator ... 29 Outline Dimensions ... 107 Voltage Channel ADC ... 30 Ordering Guide .. 107 Changing Phase Voltage Data Path .. 31 Rev. C | Page 2 of 107 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT TERMINOLOGY POWER MANAGEMENT PSM0—NORMAL POWER MODE (ALL PARTS) PSM1—REDUCED POWER MODE PSM2—LOW POWER MODE PSM3—SLEEP MODE (ALL PARTS) POWER-UP PROCEDURE HARDWARE RESET SOFTWARE RESET FUNCTIONALITY THEORY OF OPERATION ANALOG INPUTS ANALOG-TO-DIGITAL CONVERSION Antialiasing Filter ADC Transfer Function CURRENT CHANNEL ADC Current Waveform Gain Registers Current Channel HPF Current Channel Sampling di/dt CURRENT SENSOR AND DIGITAL INTEGRATOR VOLTAGE CHANNEL ADC Voltage Waveform Gain Registers Voltage Channel HPF Voltage Channel Sampling CHANGING PHASE VOLTAGE DATA PATH POWER QUALITY MEASUREMENTS Zero-Crossing Detection Zero-Crossing Timeout Phase Sequence Detection Time Interval Between Phases Period Measurement Phase Voltage Sag Detection Sag Level Set Peak Detection Overvoltage and Overcurrent Detection Overvoltage and Overcurrent Level Set Neutral Current Mismatch PHASE COMPENSATION REFERENCE CIRCUIT DIGITAL SIGNAL PROCESSOR ROOT MEAN SQUARE MEASUREMENT Current RMS Calculation Current RMS Offset Compensation Current Mean Absolute Value Calculation Current MAV Gain and Offset Compensation Voltage Channel RMS Calculation Voltage RMS Offset Compensation Voltage RMS in 3-Phase, 3-Wire Delta Configurations ACTIVE POWER CALCULATION Total Active Power Calculation Fundamental Active Power Calculation Managing Change in Fundamental Line Frequency Active Power Gain Calibration Active Power Offset Calibration Sign of Active Power Calculation Active Energy Calculation Integration Time Under Steady Load Active Energy Accumulation Modes Line Cycle Active Energy Accumulation Mode FUNDAMENTAL REACTIVE POWER CALCULATION Fundamental Reactive Power Gain Calibration Fundamental Reactive Power Offset Calibration Sign of Fundamental Reactive Power Calculation Fundamental Reactive Energy Calculation Integration Time Under Steady Load Fundamental Reactive Energy Accumulation Modes Line Cycle Reactive Energy Accumulation Mode APPARENT POWER CALCULATION Apparent Power Gain Calibration Apparent Power Offset Calibration Apparent Power Calculation Using VNOM Apparent Energy Calculation Integration Time Under Steady Load Apparent Energy Accumulation Modes Line Cycle Apparent Energy Accumulation Mode POWER FACTOR CALCULATION HARMONICS CALCULATIONS Harmonics Calcuations Theory Configuring the Harmonic Calculations Harmonic Calculations When a Phase is Monitored Harmonic Calculations When the Neutral is Monitored Configuring Harmonic Calculations Update Rate Recommended Approach to Managing Harmonic Calculations WAVEFORM SAMPLING MODE ENERGY-TO-FREQUENCY CONVERSION Synchronizing Energy Registers with CFx Outputs Energy Registers and CF Outputs for Various Accumulation Modes Sign of Sum of Phase Powers in the CFx Data Path NO LOAD CONDITION No Load Detection Based On Total Active Power and Apparent Power No Load Detection Based on Fundamental Active and Reactive Powers No Load Detection Based on Apparent Power CHECKSUM REGISTER INTERRUPTS Using the Interrupts with an MCU SERIAL INTERFACES Serial Interface Choice Communication Verification I2C-Compatible Interface I2C Write Operation I2C Read Operation I2C Read Operation of Harmonic Calculations Registers SPI-Compatible Interface SPI Read Operation SPI Read Operation of Harmonic Calculations Registers SPI Write Operation HSDC Interface ADE7880 QUICK SETUP AS ENERGY METER LAYOUT GUIDELINES CRYSTAL CIRCUIT ADE7880 EVALUATION BOARD DIE VERSION SILICON ANOMALY ADE7880 FUNCTIONALITY ISSUES FUNCTIONALITY ISSUES SECTION 1. ADE7880 FUNCTIONALITY ISSUES REGISTERS LIST OUTLINE DIMENSIONS ORDERING GUIDE
