Datasheet LTC2063 (Analog Devices) - 9
Description2µA Supply Current, Low IB, Zero-Drift Operational Amplifier
Pages / Page24 / 9 — Typical perForMance characTerisTics. Closed Loop Output Impedance. Output …
Typical perForMance characTerisTics. Closed Loop Output Impedance. Output Impedance in Shutdown. vs Frequency
Typical perForMance characTerisTics Closed Loop Output Impedance Output Impedance in Shutdown vs Frequency
LTC2063
Typical perForMance characTerisTics Closed Loop Output Impedance Output Impedance in Shutdown vs Frequency vs Frequency
1M 10G VS = 5V VS = 5V AV = +1 A 100k V = +1 1G 10k 100M 1k 10M (Ω) (Ω) Z OUT 100 Z OUT 1M 10 100k 1 10k 0.1 1k 1 10 100 1k 10k 100k 1M 1 10 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz) 2063 G31 2063 G32
Maximum Undistorted Output THD vs Frequency Amplitude vs Frequency Supply Current vs Supply Voltage
) –20 6 2.5 A P–P V = +1 VS = ±2.5 V 5 125°C –40 OUT = ±2V TAGE (V R 2.0 L = 499kΩ 85°C TION (dB) 4 –60 1.5 25°C 3 (µA) TED OUTPUT VOL I S –40°C –80 1.0 2 A AL HARMONIC DISTOR V = +1 –100 1 VS = ±2.5 0.5 TOT THD < 40dB RL = 499kΩ –120 0 0 20 100 1k 2k MAXIMUM UNDISTOR 10 100 1k 2k 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 FREQUENCY (Hz) FREQUENCY (Hz) VS (V) 2063 G33 2063 G34 2063 G35
Supply Current vs SHDN Pin Supply Current vs SHDN Pin Supply Current vs Temperature Voltage Voltage
2.2 10 3.0 VS = 5V V 9 S = 1.8V 2.0 2.5 8 1.8 7 125°C 2.0 5V 85°C 1.6 6 (µA) 5 (µA) 1.5 (µA) 25°C I S 1.4 I S I S 4 1.8V 85°C 125°C –40°C 25°C 1.0 1.2 3 2 1.0 0.5 1 0.8 –40°C 0 0 –50 –25 0 25 50 75 100 125 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 TEMPERATURE (°C) SHDN PIN VOLTAGE (V) SHDN PIN VOLTAGE (V) 2063 G36 2063 G37 2063 G38 2063f For more information www.linear.com/LTC2063 9 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Typical Applications Typical Application Related Parts
