LT6020/LT6020-1 e lecTrical characTerisTics The l denotes the specifications which apply over the specifiedtemperature range, otherwise specifications are at TA = 25°C, VS = 3V, VCM = VOUT = Mid-Supply, VDGND = 0V, VEN = 3V. DGND andEN pin specifications only apply to the LT6020-1.SYMBOL PARAMETERCONDITIONSMINTYPMAXUNITS IS Supply Current per Amplifier 85 95 μA TA = –40° to 85°C l 120 μA TA = –40° to 125°C l 135 μA Supply Current in Shutdown VEN = 0.8V 0.9 1.1 μA TA = –40° to 85°C l 1.5 μA TA = –40° to 125°C l 3 μA ts Settling Time (AV = –1) 0.1% 2.4V Output Step 12.4 μs 0.01% 2.4V Output Step 21.2 μs 0.0015% 2.4V Output Step 39.2 μs tON Enable Time AV = 1 120 µs VDGND DGND Pin Voltage Range l V– V+ – 3 V IDGND DGND Pin Current –200 nA IEN EN Pin Current –100 nA VENL EN Pin Input Low Voltage Relative to DGND l 0.8 V VENH EN Pin Input High Voltage Relative to DGND l 1.7 V Note 1: Stresses beyond those listed under Absolute Maximum Ratings Note 3: The slew rate of the LT6020 increases with the size of the may cause permanent damage to the device. Exposure to any Absolute input step. At lower supplies, the input step size is limited by the input Maximum Rating condition for extended periods may affect device common mode range. This trend can be seen in the Typical Performance reliability and lifetime. Characteristics. Note 2: Guaranteed by design. 60201fa 6 For more information www.linear.com/LT6020 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
