Datasheet LT6020, LT6020-1 (Analog Devices) - 10
DescriptionDual Micropower, 5V/μs Precision Rail-to-Rail Output Amplifier
Pages / Page20 / 10 — Typical. perForMance characTerisTics TA = 25°C, VS = ±15V, RL = 100kΩ …
File Format / SizePDF / 442 Kb
Typical. perForMance characTerisTics TA = 25°C, VS = ±15V, RL = 100kΩ unless. otherwise specified. Shutdown Supply Current vs
Typical perForMance characTerisTics TA = 25°C, VS = ±15V, RL = 100kΩ unless otherwise specified Shutdown Supply Current vs
LT6020/LT6020-1
Typical perForMance characTerisTics TA = 25°C, VS = ±15V, RL = 100kΩ unless otherwise specified. Shutdown Supply Current vs Supply Current vs Supply Voltage Temperature Start-Up Response
160 3.0 140 125°C 2.5 120 85°C VEN 2.0 5V/DIV 100 25°C 0V Y CURRENT (µA) VS = 30V 80 1.5 –40°C 60 1.0 Y CURRENT/AMPLIFIER (µA) I(V+) 40 VS = 3V 200µA/DIV SUPPL 0.5 20 SHUTDOWN SUPPL 0 0 0µA 0 5 10 15 20 25 30 –50 –25 0 25 50 75 100 125 20µs/DIV TOTAL SUPPLY VOLTAGE (V) TEMPERATURE (°C) 60201 G22 60201 G23 60201 G24
Output Saturation Voltage vs Output Saturation Voltage vs Enable/Disable Response Sink Current (Output Low) Source Current (Output High)
A 1 1 V = 1 V T T IN = 5VP-P AT 50kHz A = 125°C A = 125°C VEN TAGE (V) TAGE (V) 5V/DIV TA = 85°C TA = 85°C 0V TION VOL TION VOL 0.1 0.1 TURA T TURA T A = –40°C A = –40°C T V A = 25°C OUT 5V/DIV 0V TA = 25°C OUTPUT LOW SA OUTPUT HIGH SA 0.01 0.01 100µs/DIV 0.1 1 10 0.1 1 10 LOAD CURRENT (mA) LOAD CURRENT (mA) 60201 G24 60201 G26 60201 G27
Positive Output Overdrive Negative Output Overdrive Crosstalk vs Frequency Recovery Recovery
–40 VDGND = 0V AV = –100 AV = –100 VEN = 5V INPUT –60 OUTPUT 200mV/DIV 5V/DIV –80 0V ALK (dB) –100 0V CROSST INPUT 200mV/DIV OUTPUT 5V/DIV –120 –140100 1k 10k 100k 1M 100µs/DIV 100µs/DIV FREQUENCY (Hz) 60201 G28 60201 G29 60201 G30 60201fa 10 For more information www.linear.com/LT6020 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
