Datasheet LT6020, LT6020-1 (Analog Devices) - 3
DescriptionDual Micropower, 5V/μs Precision Rail-to-Rail Output Amplifier
Pages / Page20 / 3 — e lecTrical characTerisTics The. denotes the specifications which apply …
File Format / SizePDF / 442 Kb
e lecTrical characTerisTics The. denotes the specifications which apply over the specified
e lecTrical characTerisTics The denotes the specifications which apply over the specified
LT6020/LT6020-1
denotes the specifications which apply over the specified temperature range, otherwise specifications are at TA = 25°C, VS = ±15V, VCM = VOUT = Mid-Supply, VDGND = 0V, VEN = 5V. DGND and EN specifications only apply to the LT6020-1. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage DD Packages 20 70 µV TA = –40° to 85°C l 110 µV TA = –40° to 125°C l 120 µV MS8 Package 5 30 µV TA = –40° to 85°C l 70 µV TA = –40° to 125°C l 80 µV ∆VOSI Input Offset Voltage Drift (Note 2) DD Packages l –0.8 ±0.3 0.8 µV/°C ∆Temp MS8 Package l –0.5 ±0.2 0.5 µV/°C ∆VOSI Long Term Input Offset Voltage Stability l ±0.2 µV/Mo ∆Time IB Input Bias Current –3 ±0.1 3 nA TA = –40° to 85°C l –3 3 nA TA = –40° to 125°C l –10 10 nA IOS Input Offset Current –1 ±0.1 1 nA TA = –40° to 85°C l –1 1 nA TA = –40° to 125°C l –2 2 nA Input Noise Voltage 0.1Hz to 10Hz 1.1 µVP-P en Input Noise Voltage Density f = 10Hz 50 nV/√Hz f = 1kHz 46 nV/√Hz in Input Noise Current Density f = 1kHz 37 fA/√Hz CIN Input Capacitance Common Mode 1.5 pF Differential Mode 2.5 pF RIN Input Resistance Common Mode 17 GΩ Differential Mode 20 MΩ VICM Common Mode Input Range l V– + 1.2 V+ – 1.4 V CMRR Common Mode Rejection Ratio VCM = –13.8V to 13.6V 120 132 dB l 120 dB PSRR Supply Rejection Ratio VS = 3V to 30V 120 140 dB l 118 dB AVOL Large-Signal Voltage Gain RL = 6.98kΩ, VOUT = ±14V 110 116 dB l 108 dB RL = 100kΩ, VOUT = ±14.5V 126 138 dB l 126 dB VOL Output Swing Low (VOUT – V–) RL = 10kΩ 130 200 mV TA = –40° to 85°C l 250 mV TA = –40° to 125°C l 300 mV VOH Output Swing High (V+ – VOUT) RL = 10kΩ 100 140 mV TA = –40° to 85°C l 165 mV TA = –40° to 125°C l 190 mV ISC Short-Circuit Current VOUT = 0V, Sourcing 8 mA TA = –40° to 85°C l 5.5 mA TA = –40° to 125°C l 5 mA VOUT = 0V, Sinking 11 mA TA = –40° to 85°C l 5.5 mA TA = –40° to 125°C l 5.5 mA 60201fa For more information www.linear.com/LT6020 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
