Datasheet LT6020, LT6020-1 (Analog Devices) - 2
DescriptionDual Micropower, 5V/μs Precision Rail-to-Rail Output Amplifier
Pages / Page20 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion …
File Format / SizePDF / 442 Kb
absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT6020/LT6020-1
Total Supply Voltage (V+ to V–) ...36V Operating and Specified Temperature Range Differential Input Voltage (within Supplies) ...36V I-Grade...–40°C to 85°C Input Voltage (DGND, EN) (Relative to V–) ..36V H-Grade .. .–40°C to 125°C Input Current (+IN, –IN, DGND, EN) ... ±10mA Junction Temperature ... 150°C Output Short-Circuit Duration .. Indefinite Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) ...300°C
pin conFiguraTion
TOP VIEW TOP VIEW OUT A 1 8 V+ OUT A 1 10 V+ TOP VIEW –IN A 2 7 OUT B –IN A 2 9 OUT B A OUTA 1 8 V+ A 9 +IN A 3 11 8 –IN B +IN A 3 6 –IN B B –INA 2 7 OUTB A B V– 4 7 +IN B +INA 3 6 –INB V– 4 5 +IN B B DGND 5 6 EN V– 4 5 +INB MS8 PACKAGE DD PACKAGE DD PACKAGE 8-LEAD PLASTIC MSOP 8-LEAD (3mm × 3mm) PLASTIC DFN 10-LEAD (3mm × 3mm) PLASTIC DFN θJA = 163°C/W, θJC = 40°C/W θJA = 43°C/W, θJC = 5.5°C/W θJA = 43°C/W, θJC = 5.5°C/W EXPOSED PAD (PIN 9) IS CONNECTED TO V– (PIN 4) EXPOSED PAD (PIN 11) IS CONNECTED TO V– (PIN 4) (PCB CONNECTION OPTIONAL) (PCB CONNECTION OPTIONAL)
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT6020IDD#PBF LT6020IDD#TRPBF LGMC 8-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LT6020HDD#PBF LT6020HDD#TRPBF LGMC 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT6020IDD-1#PBF LT6020IDD-1#TRPBF LGKF 10-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LT6020HDD-1#PBF LT6020HDD-1#TRPBF LGKF 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT6020IMS8#PBF LT6020IMS8#TRPBF LTGJG 8-Lead Plastic MSOP –40°C to 85°C LT6020HMS8#PBF LT6020HMS8#TRPBF LTGJG 8-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 60201fa 2 For more information www.linear.com/LT6020 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
