Datasheet LT6020, LT6020-1 (Analog Devices) - 8
Description | Dual Micropower, 5V/μs Precision Rail-to-Rail Output Amplifier |
Pages / Page | 20 / 8 — Typical. perForMance characTerisTics TA = 25°C, VS = ±15V, RL = 100kΩ, … |
File Format / Size | PDF / 442 Kb |
Typical. perForMance characTerisTics TA = 25°C, VS = ±15V, RL = 100kΩ, unless. otherwise specified. Input Bias Current vs
LT6020/LT6020-1
Typical perForMance characTerisTics TA = 25°C, VS = ±15V, RL = 100kΩ, unless otherwise specified. Input Bias Current vs Input Bias Current vs Differential Temperature Input Voltage 0.1Hz to 10Hz Voltage Noise
4 1.00 0.75 3 0.50 IB– IB+ 2 0.25 0 500nV/DIV 1 –0.25 INPUT BIAS CURRENT (nA) –0.50 0 INPUT BIAS CURRENT (µA) –0.75 –1 –1.00 –50 –25 0 25 50 75 100 125 –6 –5 –4 –3 –2 –1 0 1 2 3 4 5 6 1s/DIV TEMPERATURE (°C) DIFFERENTIAL INPUT VOLTAGE (V) 60201 G04 60201 G05 60201 G06
Voltage Noise Density vs Maximum Undistorted Output Large-Signal Transient Response Frequency Amplitude vs Frequency (5V Step)
) 1000 P-P 35 THD < 40dBc A ) V = 1 30 Hz TAGE (V /√ 25 Y (nV 20 100 1V/DIV TED OUTPUT VOL 15 10 TAGE NOISE DENSIT VOL 5 10 0 0.01 0.1 1 10 100 1k 10k MAXIMUM UNDISTOR 0.1 1 10 10µs/DIV 60201 G09 FREQUENCY (Hz) FREQUENCY (kHz) 60201 G07 60201 G08
Large-Signal Transient Response Slew Rate vs Temperature Slew Rate vs Temperature (10V Step) (5V Step) (10V Step)
5 7 AV = 1 6 RISING EDGE 4 RISING EDGE 5 /µs) /µs) 3 4 FALLING EDGE 2V/DIV TE (V TE (V 2 FALLING EDGE 3 SLEW RA SLEW RA 2 1 1 0 0 10µs/DIV 60201 G10 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) 60201 G11 60201 G12 60201fa 8 For more information www.linear.com/LT6020 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
