Datasheet LT1097 (Analog Devices) - 2
DescriptionLow Cost, Low Power Precision Op
Pages / Page12 / 2 — ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. ELECTRICAL …
File Format / SizePDF / 198 Kb
ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. ELECTRICAL CHARACTERISTICS VS =. 15V, VCM = 0V, TA = 25
ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION ELECTRICAL CHARACTERISTICS VS = 15V, VCM = 0V, TA = 25
LT1097
W W W U ABSOLUTE MAXIMUM RATINGS
Supply Voltage .. ±20V Operating Temperature Range ...–40°C to 85°C Differential Input Current (Note 1) .. ±10mA Storage Temperature Range ..–65°C to 150°C Input Voltage ... ±20V Lead Temperature (Soldering, 10 sec).. 300°C Output Short Circuit Duration .. Indefinite
U W U PACKAGE/ORDER INFORMATION
TOP VIEW ORDER TOP VIEW ORDER V 1 PART NUMBER OS TRIM 8 VOS TRIM PART NUMBER V 1 8 OS TRIM VOS TRIM –IN 2 7 V+ LT1097CN8 –IN 2 7 V+ LT1097S8 +IN 3 6 OUT +IN 3 6 OUT V– 4 5 OVER COMP V– 4 5 OVER COMP N8 PACKAGE S8 PACKAGE 8-LEAD PLASTIC DIP 8-LEAD PLASTIC SO
C, unless otherwise noted. LT1097CN8 LT1097S8 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 10 50 10 60 µV ∆VOS Long Term Input Offset 0.3 0.3 µV/Mo ∆TIME Voltage Stability IOS Input Offset Current 40 250 60 350 pA IB Input Bias Current ±40 ±250 ±50 ±350 pA en Input Noise Voltage 0.1Hz to 10Hz 0.5 0.5 µVp-p Input Noise Voltage Density fO = 10Hz 16 16 nV/√Hz fO = 1000Hz 14 14 nV/√Hz in Input Noise Current 0.1Hz to 10Hz 2.2 2.4 pAp-p Input Noise Current Density fO = 10Hz 0.03 0.035 pA/√Hz fO = 1000Hz 0.008 0.008 pA/√Hz Input Resistance (Note 2) Differential Mode 30 80 25 70 MΩ Common Mode 1012 8•1011 Ω Input Voltage Range ±13.5 ±14.3 ±13.5 ±14.3 V CMRR Common Mode Rejection Ratio VCM = ±13.5V 115 130 115 130 dB PSRR Power Supply Rejection Ratio VS = ±1.2V to ±20V 114 130 114 130 dB AVOL Large Signal Voltage Gain VO = ±12V, RL = 10k 700 2500 700 2500 V/mV VO = ±10V, RL = 2k 250 1000 250 1000 V/mV VOUT Output Voltage Swing RL = 10k ±13 ±13.8 ±13 ±13.8 V RL = 2k ±11.5 ±13 ±11.5 ±13 V SR Slew Rate 0.1 0.2 0.1 0.2 V/µs GBW Gain Bandwidth Product 700 700 kHz IS Supply Current 350 560 350 560 µA Offset Adjustment Range RPOT = 10k, Wiper to V+ ±600 ±600 µV Minimum Supply Voltage (Note 3) ±1.2 — ±1.2 — V 2
