Datasheet LTC1050 (Analog Devices) - 3
DescriptionPrecision Zero-Drift Operational Amplifier with Internal Capacitors
Pages / Page16 / 3 — ELECTRICAL CH. ARA TERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 232 Kb
ELECTRICAL CH. ARA TERISTICS The. denotes specifications which apply over the full operating temperature
ELECTRICAL CH ARA TERISTICS The denotes specifications which apply over the full operating temperature
LTC1050
ELECTRICAL CH C ARA TERISTICS The
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VS =
5V LTC1050AM LTC1050AC PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Input Noise Current f = 10Hz (Note 4) 1.8 1.8 fA/√Hz Common Mode Rejection Ratio VCM = V– to 2.7V 114 140 114 140 dB ● 110 110 dB Power Supply Rejection Ratio VS = ±2.375V to ±8V ● 125 140 125 140 dB Large-Signal Voltage Gain RL = 10k, VOUT = ±4V ● 130 160 130 160 dB Maximum Output Voltage Swing RL = 10k ● ± 4.7 ±4.85 ±4.7 ±4.85 V RL = 100k ±4.95 ±4.95 V Slew Rate RL = 10k, CL = 50pF 4 4 V/µs Gain Bandwidth Product 2.5 2.5 MHz Supply Current No Load 1 1.5 1 1.5 mA ● 2.3 2.3 mA Internal Sampling Frequency 2.5 2.5 kHz
The
C. VS =
5V LTC1050M/H LTC1050C PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Input Offset Voltage (Note 3) ±0.5 ±5 ±0.5 ±5 µV Average Input Offset Drift (Note 3) ● ±0.01 ±0.05 ±0.01 ±0.05 µV/°C Long Term Offset Voltage Drift 50 50 nV/√Mo Input Offset Current (Note 5) ±20 ±100 ±20 ±125 pA ● ±300 ±200 pA Input Bias Current (Note 5) ±10 ±50 ±10 ±75 pA ● ±2000 ±150 pA Input Noise Voltage RS = 100Ω, 0.1Hz to 10Hz (Note 6) 1.6 1.6 µVP-P RS = 100Ω, DC to 1Hz 0.6 0.6 µVP-P Input Noise Current f = 10Hz (Note 4) 1.8 1.8 fA/√Hz Common Mode Rejection Ratio VCM = V– to 2.7V 114 130 114 130 dB LTC1050M/C ● 110 110 dB LTC1050H ● 100 dB Power Supply Rejection Ratio VS = ±2.375V to ±8V, LTC1050M/C ● 120 140 120 140 dB LTC1050H ● 110 dB Large-Signal Voltage Gain RL = 10k, VOUT = ±4V ● 120 160 120 160 dB Maximum Output Voltage Swing RL = 10k ● ± 4.7 ±4.85 ±4.7 ±4.85 V RL = 100k ±4.95 ±4.95 V Slew Rate RL = 10k, CL = 50pF 4 4 V/µs Gain Bandwidth Product 2.5 2.5 MHz Supply Current No Load 1 1.5 1 1.5 mA ● 2.3 2.3 mA Internal Sampling Frequency 2.5 2.5 kHz
Note 1:
Note 4:
Current Noise is calculated from the formula: In = √(2q • Ib) of the device may be impaired. where q = 1.6 • 10–19 Coulomb.
Note 2:
Connecting any terminal to voltages greater than V+ or less than
Note 5:
At TA ≤ 0°C these parameters are guaranteed by design and not V– may cause destructive latchup. It is recommended that no sources tested. operating from external supplies be applied prior to power-up of the
Note 6:
Every lot of LTC1050AM and LTC1050AC is 100% tested for LTC1050. Broadband Noise at 1kHz and sample tested for Input Noise Voltage at
Note 3:
These parameters are guaranteed by design. Thermocouple effects 0.1Hz to 10Hz. preclude measurement of these voltage levels in high speed automatic test systems. VOS is measured to a limit determined by test equipment capability. 1050fb 3
