Datasheet LTC6430-15 (Analog Devices) - 2
DescriptionHigh Linearity Differential RF/IF Amplifier/ADC Driver
Pages / Page28 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion. …
absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
absoluTe MaxiMuM raTings pin conFiguraTion (Note 1) orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC6430-15
Total Supply Voltage (VCC to GND)...5.5V TOP VIEW Amplifier Output Current (+OUT) ...105mA Amplifier Output Current (–OUT) ...105mA +IN GND V CC DNC DNC DNC RF Input Power, Continuous, 50Ω (Note 2).. +15dBm 24 23 22 21 20 19 RF Input Power, 100µs Pulse, 50Ω (Note 2) ..+20dBm DNC 1 18 +OUT Operating Temperature Range (T DNC 2 17 GND CASE) ...–40°C to 85°C Storage Temperature Range .. –65°C to 150°C DNC 3 25 16 T_DIODE Junction Temperature (T DNC 4 GND 15 DNC J) .. 150°C Lead Temperature (Soldering, 10 sec) ...300°C DNC 5 14 GND DNC 6 13 –OUT 7 8 9 10 11 12 –IN GND V CC DNC DNC DNC UF PACKAGE 24-LEAD (4mm × 4mm) PLASTIC QFN TJMAX = 150°C, θJC = 40°C/W EXPOSED PAD (PIN 25) IS GND, MUST BE SOLDERED TO PCB
orDer inForMaTion
The LTC6430-15 is available in two grades. The A-grade guarantees a minimum OIP3 at 240MHz while the B-grade does not.
LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6430AIUF-15#PBF LTC6430AIUF-15#TRPBF 43015 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C LTC6430BIUF-15#PBF LTC6430BIUF-15#TRPBF 43015 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. Consult LTC Marketing for information on nonstandard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
D c elecTrical characTerisTics The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 100Ω. Typical measured DC electrical performance using Test Circuit A (Note 3). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VS Operating Supply Range 4.75 5.0 5.25 V IS,TOT Total Supply Current All VCC Pins Plus +OUT and –OUT 126 160 190 mA l 93 216 mA IS,OUT Total Supply Current to OUT Pins Current to +OUT and –OUT 112 146 176 mA l 79 202 mA IVCC Current to VCC Pin Either VCC Pin May Be Used 12 14 22 mA l 11 26 mA 643015f 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information Differential S Parameters Typical Applications Package Description Typical Application Related Parts
