Datasheet LTC6417 (Analog Devices) - 7
Description1.6GHz Low Noise High Linearity Differential Buffer/16-Bit ADC Driver with Fast Clamp
Pages / Page32 / 7 — ac elecTrical characTerisTics. The. denotes the specifications which …
ac elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
ac elecTrical characTerisTics The denotes the specifications which apply over the full operating
LTC6417
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. V+ = 5V unless otherwise noted, GND = 0V, RLOAD = 500Ω,CLOAD = 6pF. VCM = 1.25V, CLHI = V+, PWRADJ = VCC, SHDN = 0V unless otherwise noted. VINCM is defined as (IN+ + IN–)/2. VOUTCM is defined as (OUT+ + OUT–)/2. VINDIFF is defined as (IN+ – IN–). VOUTDIFF is defined as (OUT+ – OUT–). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –73 dBc VOUTDIFF = 2.4VP-P –79 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 41 dBm P1dB Output 1dB Compression Point 15.6 dBm
380MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –66 dBc VOUTDIFF = 2.4VP-P –68 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –68 dBc VOUTDIFF = 2.4VP-P –77 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 36 39 dBm P1dB Output 1dB Compression Point 15.3 dBm
400MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –65 dBc VOUTDIFF = 2.4VP-P –68 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –68 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 39 dBm P1dB Output 1dB Compression Point 15.3 dBm
500MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –65 dBc VOUTDIFF = 2.4VP-P –67 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –64 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 37 dBm P1dB Output 1dB Compression Point 15.0 dBm
600MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –60 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –58 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 34 dBm P1dB Output 1dB Compression Point 14.7 dBm
700MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –55 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –52 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 31 dBm P1dB Output 1dB Compression Point 14.2 dBm
Note 1:
Note 3:
The LTC6417C is guaranteed to meet specified performance from may cause permanent damage to the device. Exposure to any Absolute 0°C to 70°C. It is designed, characterized and expected to meet specified Maximum Rating condition for extended periods may affect device performance from –40°C and 105°C case temperature range but is not reliability and lifetime. tested or QA sampled at these temperatures. The LT6417I is guaranteed to
Note 2:
The LTC6417C/LTC6417I is guaranteed functional over the case meet specified performance from –40°C to 105°C case temperature range. temperature operating range of –40°C to 105°C. θJC = 6.8°C/W.
Note 4:
This parameter is pulse tested. 6417f 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions DC Test Circuit Schematic Block Diagram Applications Information Package Description Typical Application Related Parts
