Datasheet LTC6362 (Analog Devices) - 2
DescriptionPrecision, Low Power Rail-to-Rail Input/Output Differential Op Amp/SAR ADC Driver
Pages / Page22 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
File Format / SizePDF / 372 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC6362
Total Supply Voltage (V+ – V–) ...5.5V Specified Temperature Range (Note 5) Input Current (+IN, –IN, VOCM, SHDN) (Note 2) ...±10mA LTC6362C .. 0°C to 70°C Output Short-Circuit Duration (Note 3) .. Indefinite LTC6362I ...–40°C to 85°C Operating Temperature Range (Note 4) LTC6362H .. –40°C to 125°C LTC6362C/LTC6362I ..–40°C to 85°C Maximum Junction Temperature .. 150°C LTC6362H .. –40°C to 125°C Storage Temperature Range .. –65°C to 150°C
PIN CONFIGURATION
TOP VIEW TOP VIEW –IN 1 8 +IN –IN 1 8 +IN VOCM 2 7 SHDN VOCM 2 7 SHDN V+ 3 6 V– V+ 3 6 V– +OUT 4 5 –OUT +OUT 4 9 5 –OUT V– MS8 PACKAGE 8-LEAD PLASTIC MSOP DD PACKAGE TJMAX = 150°C, θJA = 273°C/W, θJC = 45°C/W 8-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 39.7°C/W, θJC = 45°C/W EXPOSED PAD (PIN 9) IS V–, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LTC6362CMS8#PBF LTC6362CMS8#TRPBF LTGCN 8-Lead Plastic MSOP 0°C to 70°C LTC6362IMS8#PBF LTC6362IMS8#TRPBF LTGCN 8-Lead Plastic MSOP –40°C to 85°C LTC6362HMS8#PBF LTC6362HMS8#TRPBF LTGCN 8-Lead Plastic MSOP –40°C to 125°C LTC6362CDD#PBF LTC6362CDD#TRPBF LGCM 8-Lead (3mm × 3mm) Plastic DFN 0°C to 70°C LTC6362IDD#PBF LTC6362IDD#TRPBF LGCM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LTC6362HDD#PBF LTC6362HDD#TRPBF LGCM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 6362fa 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
