Datasheet LTC6362 (Analog Devices) - 5
DescriptionPrecision, Low Power Rail-to-Rail Input/Output Differential Op Amp/SAR ADC Driver
Pages / Page22 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 372 Kb
LTC6362
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. V+ = 5V, V– = 0V, VCM = VOCM = VICM = 2.5V, VSHDN = open. VS is defined as (V+ – V–). VOUTCM is defined as (V+OUT + V–OUT)/2. VICM is defined as (V+IN + V–IN)/2. VOUTDIFF is defined as (V+OUT – V–OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIL SHDN Input Logic Low l 0.8 V VIH SHDN Input Logic High l 2 V tON Turn-On Time 2 μs tOFF Turn-Off Time 2 μs
Note 1:
Note 9:
Input common mode range is tested by verifying that at the limits may cause permanent damage to the device. Exposure to any Absolute stated in the Electrical Characteristics table, the differential offset (VOSDIFF) Maximum Rating condition for extended periods may affect device and common mode offset (VOSCM) have not deviated by more than ±1mV reliability and lifetime. and ±35mV respectively compared to the VICM = 2.5V (at VS = 5V) and
Note 2:
Input pins (+IN, –IN, V V OCM and SHDN) are protected by steering ICM = 1.5V (at VS = 3V) cases. diodes to either supply. If the inputs should exceed either supply voltage, Output common mode range is tested by verifying that at the limits stated the input current should be limited to less than 10mA. In addition, the in the Electrical Characteristics table, the common mode offset (VOSCM) inputs +IN, –IN are protected by a pair of back-to-back diodes. If the has not deviated by more than ±15mV compared to the VOCM = 2.5V differential input voltage exceeds 1.4V, the input current should be limited (at VS = 5V) and VOCM = 1.5V (at VS = 3V) cases. to less than 10mA.
Note 10:
Input CMRR is defined as the ratio of the change in the input
Note 3:
A heat sink may be required to keep the junction temperature common mode voltage at the pins +IN or –IN to the change in differential below the absolute maximum rating when the output is shorted input referred offset voltage. Output CMRR is defined as the ratio of indefinitely. the change in the voltage at the VOCM pin to the change in differential
Note 4:
The LTC6362C and LTC6362I are guaranteed functional over input referred offset voltage. This specification is strongly dependent on the operating temperature range of –40°C to 85°C. The LTC6362H is feedback ratio matching between the two outputs and their respective guaranteed functional over the operating temperature range of –40°C to inputs and it is difficult to measure actual amplifier performance (see 125°C. Effects of Resistor Pair Mismatch in the Applications Information section
Note 5:
The LTC6362C is guaranteed to meet specified performance from of this data sheet). For a better indicator of actual amplifier performance 0°C to 70°C.The LTC6362I is guaranteed to meet specified performance independent of feedback component matching, refer to the PSRR from –40°C to 85°C. The LTC6362C is designed, characterized and specification. expected to meet specified performance from –40°C to 85°C, but is not
Note 11:
Differential power supply rejection (PSRR) is defined as the tested or QA sampled at these temperatures. The LTC6362H is guaranteed ratio of the change in supply voltage to the change in differential input to meet specified performance from –40°C to 125°C. referred offset voltage. Common mode power supply rejection (PSRRCM)
Note 6:
Differential input referred offset voltage includes offset due to is defined as the ratio of the change in supply voltage to the change in the input offset current across 1k source resistance. common mode offset voltage.
Note 7:
Maximum differential input referred offset voltage drift is
Note 12:
Supply voltage range is guaranteed by power supply rejection determined by a large sampling of typical parts. Drift is not guaranteed by ratio test. test or QA sampled at this value.
Note 8:
Input bias current is defined as the maximum of the input currents flowing into either of the input pins (–IN and +IN). Input Offset current is defined as the difference between the input currents (I + – OS = IB – IB ). 6362fa 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
