Datasheet LTC6362 (Analog Devices) - 6
Description | Precision, Low Power Rail-to-Rail Input/Output Differential Op Amp/SAR ADC Driver |
Pages / Page | 22 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Differential Input Offset Voltage. … |
File Format / Size | PDF / 372 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Differential Input Offset Voltage. Input Offset Current. vs Temperature
LTC6362
TYPICAL PERFORMANCE CHARACTERISTICS Differential Input Offset Voltage Input Offset Current Differential Input Offset Voltage vs Temperature vs Temperature vs Input Common Mode Voltage
300 100 300 V V VS = 5V, 0V 250 S = ±2.5V S = ±2.5V V 250 ICM = 0V 75 VICM = 0V VOCM = 2.5V 200 VOCM = 0V VOCM = 0V 200 TYPICAL UNIT FIVE TYPICAL UNITS 50 FIVE TYPICAL UNITS 150 150 100 25 100 50 0 50 0 –25 0 –50 –50 –50 –100 INPUT OFFSET CURRENT (nA) –100 TA = 125°C –150 –75 –150 TA = 25°C DIFFERENTIAL INPUT OFFSET VOLTAGE (µV) DIFFERENTIAL INPUT OFFSET VOLTAGE (µV) TA = –40°C –200 –100 –200 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 TEMPERATURE (°C) TEMPERATURE (°C) INPUT COMMON MODE VOLTAGE (V) 6362 G01 6362 G02 6362 G03
Common Mode Offset Voltage Input Bias Current vs Input vs Temperature Common Mode Voltage Supply Current vs Temperature
15 800 1.2 V V S = ±2.5V S = 5V V 600 ICM = 0V 10 VOCM = 0V 400 1.1 FIVE TYPICAL UNITS 200 5 0 VS = 5V –200 1.0 0 –400 VS = 3V –600 0.9 –5 –800 INPUT BIAS CURRENT (nA) –1000 SUPPLY CURRENT (mA) 0.8 –10 –1200 COMMON MODE OFFSET VOLTAGE (mV) –1400 –15 –1600 0.7 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) INPUT COMMON MODE VOLTAGE (V) TEMPERATURE (°C) 6362 G04 6362 G05 6362 G06
Supply Current Shutdown Supply Current vs Supply Voltage Supply Current vs SHDN Voltage vs Supply Voltage
1.2 1.2 V 90 S = 5V VSHDN = V– 80 1.0 1.0 70 0.8 0.8 60 50 0.6 0.6 40 0.4 0.4 30 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) SUPPLY CURRENT (µA) 20 0.2 TA = 125°C 0.2 TA = 125°C TA = 125°C TA = 25°C TA = 25°C 10 TA = 25°C TA = –40°C TA = –40°C TA = –40°C 0 0 0 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 SUPPLY VOLTAGE (V) SHDN VOLTAGE (V) SUPPLY VOLTAGE (V) 6362 G07 6362 G08 6362 G09 6362fa 6 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
