Datasheet LTC6410-6 (Analog Devices) - 6
DescriptionLow Distortion, Low Noise Differential IF Amplifier with Configurable Input Impedance
Pages / Page16 / 6 — AC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which …
File Format / SizePDF / 359 Kb
AC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
AC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC6410-6
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, SHDN = 2V, +IN is shorted to +TERM, –IN is shorted to –TERM, VINCM = VBIAS = 1.5V, input source resistance (RS) is 25
Ω
on each input (50
Ω
differential), RL = 50
Ω
from +OUT to –OUT, +IN and –IN are AC-coupled, unless otherwise noted. VBIAS is defi ned as the voltage on theVBIAS pin. VOUTCM is defi ned as (+OUT + –OUT)/2. VINCM is defi ned as (+IN + –IN)/2. VINDIFF is defi ned as (+IN – –IN). VOUTDIFF is defi ned as (+OUT – –OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
NF Noise Figure ZIN = 50Ω (Note 5) 11 dB ZIN = 200Ω 7 dB
240MHz Signal
HD2 Second Harmonic Distortion VOUTDIFF = 0dBm –66 dBc HD3 Third Harmonic Distortion VOUTDIFF = 0dBm –52 dBc IM3 Third Order Intermodulated F1 = 239.5MHz, F2 = 240.5MHz, VOUTDIFF = 0dBm/Tone –54 dBc Distortion F1 = 239.5MHz, F2 = 240.5MHz, VOUTDIFF = –5dBm/Tone –63 dBc F1 = 239.5MHz, F2 = 240.5MHz, VOUTDIFF = 0dBm/Tone, –64 dBc VCC = 5V, VBIAS = 2.5V, SHDN = 3V OIP3 Output Third-Order Intercept F1 = 239.5MHz, F2 = 240.5MHz, VOUTDIFF = 0dBm/Tone 27 dBm F1 = 239.5MHz, F2 = 240.5MHz, VOUTDIFF = –5dBm/Tone 27 dBm F1 = 239.5MHz, F2 = 240.5MHz, VOUTDIFF = 0dBm/Tone, 32 dBm VCC = 5V, VBIAS = 2.5V, SHDN = 3V P1dB Output 1dB Compression Point 12.8 dBm NF Noise Figure ZIN = 50Ω (Note 5) 11 dB ZIN = 200Ω 8 dB
380MHz Signal
HD2 Second Harmonic Distortion VOUTDIFF = 0dBm –57 dBc HD3 Third Harmonic Distortion VOUTDIFF = 0dBm –45 dBc IM3 Third Order Intermodulated F1 = 379.5MHz, F2 = 380.5MHz, VOUTDIFF = 0dBm/Tone –51 dBc Distortion F1 = 379.5MHz, F2 = 380.5MHz, VOUTDIFF = –5dBm/Tone –64 dBc F1 = 379.5MHz, F2 = 380.5MHz, VOUTDIFF = 0dBm/Tone, –60 dBc VCC = 5V, VBIAS = 2.5V, SHDN = 3V OIP3 Output Third-Order Intercept F1 = 379.5MHz, F2 = 380.5MHz, VOUTDIFF = 0dBm/Tone 26 dBm F1 = 379.5MHz, F2 = 380.5MHz, VOUTDIFF = –5dBm/Tone 27 dBm F1 = 379.5MHz, F2 = 380.5MHz, VOUTDIFF = 0dBm/Tone, 30 dBm VCC = 5V, VBIAS = 2.5V, SHDN = 3V P1dB Output 1dB Compression Point 10.8 dBm NF Noise Figure ZIN = 50Ω (Note 5) 12 dB ZIN = 200Ω 8 dB
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings sampled at these temperatures. The LT6410I-6 is guaranteed to meet may cause permanent damage to the device. Exposure to any Absolute specifi ed performance from –40°C to 85°C. Maximum Rating condition for extended periods may affect device
Note 4:
This parameter is pulse tested. reliability and lifetime.
Note 5:
en can be calculated from ZIN = 50Ω NF with the formula:
Note 2:
The LTC6410C-6/LTC6410I-6 is guaranteed functional over the operating temperature range of –40°C to 85°C. NF e 10 – 1)4kT50
Note 3:
The LTC6410C-6 is guaranteed to meet specifi ed performance n = (10 from 0°C to 70°C. It is designed, characterized and expected to meet where specifi ed performance from –40°C and 85°C but is not tested or QA k = Boltzmann’s constant and T = absolute temperature 64106fa 6
