Datasheet LTC6404 (Analog Devices) - 5
Description600MHz, Low Noise, High Precision Fully Differential Input/Output Amplifier/Driver
Pages / Page28 / 5 — LTC6404 DC ELECTRICAL CHARACTERISTICS The. denotes the specifi cations …
File Format / SizePDF / 347 Kb
LTC6404 DC ELECTRICAL CHARACTERISTICS The. denotes the specifi cations which apply over
LTC6404 DC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over
LTC6404
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = Mid-Supply, VSHDN = OPEN, RL = OPEN, RBAL = 100k (See Figure 1). For the LTC6404-1: RI = 100Ω, RF = 100Ω. For the LTC6404-2: RI = 100Ω, R + F = 200Ω. For the LTC6404-4: RI = 100Ω, RF = 402Ω, unless otherwise noted. VS is defi ned (V+ – V–). VOUTCM = (VOUT + VOUT )/2. V + + ICM is defi ned (VIN + VIN )/2. VOUTDIFF is defi ned (VOUT – VOUT ). VINDIFF = (VINP – VINM) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIL SHDN Input Logic Low VS = 2.7V to 5V l V+ – 2.1 V VIH SHDN Input Logic High VS = 2.7V to 5V l V+ – 0.6 V RSHDN SHDN Pin Input Impedance VS = 5V, VSHDN = 2.9V to 0V l 38 66 94 kΩ tON Turn-On Time VS = 3V, VSHDN = 0.5V to 3V 750 ns tOFF Turn-Off Time VS = 3V, VSHDN = 3V to 0.5V 300 ns
LTC6404-1 AC ELECTRICAL CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = Mid-Supply, VSHDN = OPEN, RI = 100Ω, RF = 100Ω, RL = 200Ω (See Figure 2) unless otherwise noted. VS is defi ned (V+ – V–). V + + + OUTCM = (VOUT + VOUT )/2. VICM is defi ned as (VIN + VIN )/2. VOUTDIFF is defi ned as (VOUT – VOUT ). VINDIFF = (VINP – VINM). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SR Slew Rate VS = 3V to 5V 450 V/μs GBW Gain-Bandwidth Product VS = 3V to 5V, RI = 100Ω, RF = 499Ω, 500 MHz fTEST = 500MHz f3dB –3dB Frequency (See Figure 2) VS = 3V to 5V l 300 600 MHz HDSEIN 10MHz Distortion VS = 3V, VOUTDIFF = 2VP-P Single-Ended Input 2nd Harmonic –88 dBc 3rd Harmonic –91 dBc HDDIFFIN 10MHz Distortion VS = 3V, VOUTDIFF = 2VP-P Differential Input 2nd Harmonic –102 dBc 3rd Harmonic –91 dBc IMD10M Third-Order IMD at 10MHz VS = 3V, VOUTDIFF = 2VP-P –93 dBc f1 = 9.5MHz, f2 = 10.5MHz OIP310M OIP3 at 10MHz (Note 12) 50 dBm tS Settling Time 1% Settling 10 ns 2V Step at Output 0.1% Settling 13 ns 0.01% Settling 17 ns NF Noise Figure, RS = 50Ω f = 10MHz 13.4 dB f3dBFILTER Differential Filter 3dB Bandwidth (Note 13) 88.5 MHz 6404f 5
