Datasheet AD8352 (Analog Devices) - 8
Description2 GHz Ultralow Distortion Differential RF/IF Amplifier
Pages / Page19 / 8 — AD8352. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. RG = 20Ω. RG = …
RevisionC
File Format / SizePDF / 464 Kb
AD8352. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. RG = 20Ω. RG = 43Ω. RG = 100Ω. N (. G = 182Ω. G = 520Ω. G = 383Ω. RG = 715Ω. 100. 10k
AD8352 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS RG = 20Ω RG = 43Ω RG = 100Ω N ( G = 182Ω G = 520Ω G = 383Ω RG = 715Ω 100 10k
AD8352 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 25 30 25 20 RG = 20Ω RG = 43Ω 20 15 RG = 100Ω B) B) 15 RG = 100Ω d d N ( 10 N ( R AI AI G = 182Ω G 10 R G G = 520Ω R 5 G = 383Ω 5 RG = 715Ω 0 0 –5 –5 10 100 1k 10k
036
10 100 1k 10k
039
FREQUENCY (MHz) FREQUENCY (MHz)
05728- 05728- Figure 4. Gain vs. Frequency for a 200 Ω Differential Load with Baluns, Figure 7. Gain vs. Frequency for a 1 kΩ Differential Load Without Baluns, AV = 18 dB, 12 dB, and 6 dB RD/CD Open, AV = 25 dB, 14 dB, 10 dB, 6 dB, and 3 dB
25 13.0 11.0 RL = 1kΩ 12.5 RG = 182Ω 10.5 –40°C T 20 C = 0.002dB/°C RG = 62Ω 12.0 10.0 +85°C 11.5 +25°C 9.5 15 RG = 190Ω 11.0 9.0 B) B) B) d d d N ( 10 N ( 10.5 8.5 N ( –40°C AI AI AI G RG = 3kΩ G G 10.0 8.0 5 +85°C 9.5 7.5 R +25°C L = 200Ω 9.0 7.0 R 0 G = 118Ω TC = 0.004dB/°C 8.5 6.5 –5 8.0 6.0 10 100 1k 10k
037
10 100 1k 10k
040
05728- 05728- Figure 5. Gain vs. Frequency for a 1 kΩ Differential Load with Baluns, Figure 8. Gain vs. Frequency over Temperature (−40°C, +25°C, +85°C) AV = 18 dB, 12 dB, and 6 dB Without Baluns, AV = 10 dB, RL = 200 Ω and 1 kΩ
25 80 RG = 19Ω 20 70 RL = 200Ω 60 15 RG = 64Ω B) B) R d 50 L = 1kΩ R d G = 118Ω N ( 10 AI RR ( G R 40 G = 232Ω CM 5 30 RG = 392Ω 0 20 –5 10 10 100 1k 10k
038
10 100 1000
043
FREQUENCY (MHz)
05728-
FREQUENCY (MHz)
05728- Figure 6. Gain vs. Frequency for a 200 Ω Differential Load Without Baluns, Figure 9. CMRR vs. Frequency, RL = 200 Ω and 1 kΩ, RD/CD Open, AV = 22 dB, 14 dB, 10 dB, 6 dB, and 3 dB Differential Source Resistance Rev. C | Page 8 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS NOISE DISTORTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION GAIN AND DISTORTION ADJUSTMENT (DIFFERENTIAL INPUT) SINGLE-ENDED INPUT OPERATION NARROW-BAND, THIRD-ORDER INTERMODULATION CANCELLATION HIGH PERFORMANCE ADC DRIVING LAYOUT AND TRANSMISSION LINE EFFECTS EVALUATION BOARD EVALUATION BOARD LOADING SCHEMES SOLDERING INFORMATION EVALUATION BOARD SCHEMATICS OUTLINE DIMENSIONS ORDERING GUIDE
